Homemade Speaker
Intro: Homemade Speaker
Homemade speakers are fairly simple and easy to make. I got the idea to make this when my brother had to make a speaker for physics class and well i decided to make an instructable for it. So here it goes...
Supplies Hardware
X1 Electromagnetic wire Wire Strippers
X1 Regular disposable drinking cup (NOT Plastic!!) Electrical tape
X1 Paper plate 12" (for sub woofer) Soldering skillz and equipment
X1 Small Paper Dixie cup 3oz. ( for tweeter) Hot glue gun
X3 Semi-powerful magnet
X1 boom box (something that has red and black ports for speakers)
You also need some 3 ft.x 1ft. plywood and nailing materials
X6 Rubber bands...
Supplies Hardware
X6 Rubber bands...
STEP 1: Cutting the Paper Down
You need to make both the tweeter and mid range smaller in size so you need to have a two inch base for the mid and a 1/4 of an inch base for the tweeter
STEP 2: Wrap It Up!! (not Really)
Now you need to start putting the electromagnetic wire into coils. You need some left over wire so you can solder it onto more wire (like 5 inches).
STEP 3: Glueing It Together
Now you need to halve the rubber bands and glue them on to the sub woofer, mid range and the tweeter. The sub woofer needs 6 halves, and the tweeter and mid range needs 3.
STEP 4: Soldering
For the connections all you need to do is solder them like so.
boom box & connection wire & connection wire -> tweeter coil-> connection & connection wire -> mid coil -> connection wire & connection wire -> sub coil -> connection wire & connection wire & boom box
legend
& = twist together
-> = solder
if confused look at the pic
legend
& = twist together
-> = solder
STEP 5: Making the Speaker Box
Cut holes in the plywood and leave about a one inch gap in between the board and the paper plates
hot glue the rubber bands to the board have them tight but not too tight so they cant vibrate
STEP 6: Connections
Now were almost done!
The red and black connectors at the back a boom box should be able to click up and down...
Click them both up and slide one connection into the red slot and one into the black slot it shouldn't matter what connection goes into what slot.
STEP 7: Finishing Up and Performance Enhancements
Now turn on the boom box with some music stand up the plywood and put the magnet close to the wire and enjoy your music making creation.
In order for your sound to get louder and better quality try these things:
-Use a larger gauge wire for the midrange and even bigger for the subwoofer
- If you have a multimeter try to match the impedance of the stereo with the impedance (resistance) of your speakers, if you are unsure of the impedance of you sound source make the amount of wire wraps equal 8 Ohms
- Wrap the wires neatly and glue them evenly to the plates
- Make sure that your sound system can put out enough power for the speakers but make sure the coils don't get hot
And if you still aren't satisfied with the sound quality don't use paper plates and use something that is meant for speakers, or just buy some speakers
58 Comments
KartikG6 8 years ago
robertje 7 years ago
F3onix 10 years ago
ABSOLUTELY SUPPER FANTASTICALLY AWESOME. LOVE ALL OF YOU GUYS *t&c apply. Only for gold members! :(
CamoBedding 12 years ago
TheLodgeShop 12 years ago
squirt8500 13 years ago
LexanPanda 12 years ago
s omer 12 years ago
squirt8500 12 years ago
Unitrix 14 years ago
squirt8500 14 years ago
hitachi8 13 years ago
absolutely no difference .
jj.inc 14 years ago
jj.inc 14 years ago
