Homemade Well Tuned Pan Flute
Intro: Homemade Well Tuned Pan Flute
This Instructable is splitted in two parts: theory and practice. If you are not interested in all the math and physics behind the project, you can jump directly to the practice section. If you want to know how to retrive all measurement, or even to customize your pipes, then proceed with next step.
STEP 1: Theory
As I've aforementioned, you can skip this passage if you don't want (or need) to understand the physics beyond a pan flute.
OK, if you're reading those words you want to know more. I'm here for this!
A pan flute is a mere group of tubes with a closed end (called closed cylinder, even if one end is open). Each tube have a different length but, usually, the same diameter of all other tubes.
The length of the tube influence the pitch: longer tubes produce lower notes, shorter tubes produce higher notes.
The inner diameter of the tube influence the speed of blow needed to make the sound audible: smaller diameter means less blow, greater diameter means more blow.
Pretty simple, uh? No math, no strange formulas...
Now we need to find a precise relation between tube length and note pitch. Luckily, some physician (well, actually a lot of physician) already studied this matter creating and developing a branch of physics called acoustic. So we can "stole" their results to serve our scopes.
The formula we need is the one in the first pic. Here is the meaning of various symbols:
- L is the length of the tube
- v is the speed of sound
- f is the frequency
Fine. Now we need to determine which notes we want to produce, and their frequencies. I'm going to make a full octave pan flute, so I need 13 tubes: C, C#/Db, D, D#/Eb, E, F, F#/Gb, G, G#/Ab, A, A#/Bb, B and C again. Each tube will produce a note a semitone higher than the previous one and a semitone lower than the next one.
Since it's is too generic saying "I want to play an E", we must specify also the octave. In my case the first C is a C4 and the last C is a C5. This make the A an A4, with a frequency defined to be 440 Hz (modern concert pitch). From this we can determine all other frequencies using the second formula (second pic, obviously). The n is the number of semitones between the note we want and the A4. If the note is lower than n will be negative, if the note is higher it will be positive.
STEP 2: Theory Part II - Calculations
Now we have the basis to determine the tubes length. First we find the frequencies of all notes we choose. This can be done easily with Excel, Derive, Mathematica, even with Windows' Calc.
As a math student I love Mathematica, so I will use it. However, "my" frequencies are
261.6, 277.2, 293.7, 311.1, 329.6, 349.2, 370, 392, 415.3, 440, 466.2, 493.9, 523.3
rounded to first decimal digit, measured in hertz. Using the first formula shown in the previous step we obtain the list of length:
31.69, 29.91, 28.23, 26.65, 25.15, 23.74, 22.41, 21.15, 19.96, 18.84, 17.78, 16.79, 15.84
rounded to second decimal digit, measured in centimeters.
A "virtual" pan flute made using those length and laying all tubes on a table is shown in the first pic. The external diameter of those pipes is 2 cm, maybe too wide (and bigger than the one I've realized).
The disposition of tubes, in my opinion, is not so good, because of my lack of memory. If you ask me where is a note on a piano I can find it almost instantly, but if you ask me the same thing on this arrangement I will need at least two seconds, a really long time if you are playing something. So the disposition I chose is similar to that of key on a keyboard, but the accidentals (black keys) are nearest to the player and have been lowered. The second image is another virtual model of the pan flute made this way.
Later I will explain how to dispose everything even better.
Theoretic lessons are gone, now let's do something more practical!
STEP 3: Materials and Tools
Materials we need:
- about 3 m of metal or plastic pipe (if you use metal try to avoid copper)
- duct tape of any kind
- strings/shoelaces/yarn/whatever you want to keep tubes together
- 13 pieces of whatever you can use to close one and of a pipe (coins, metal or plastic scrap, wood, cardboard... remember that it will cover the end from outside, and cannot be inserted like a cork on a bottle because this will shorten the air column and change the note produced).
Please make sure that you can cut all pieces from your pipes because it may be difficult to join two pieces together without compromise the sound. My local store sells only 1 or 2 m long tubes, and with 3 short (1 m) tubes you can do every pipe. The inner diameter should be not too big nor too small: a 1-1.5 cm of inner diameter is fine.
Tools we need:
- a saw or a tube-cutter
- a measuring tape/long caliber/big printer (I will explain this later)
- something to write on tubes
- needle files
- tuner/good ear (optional)
- clear glue (optional)
If you don't have one, I suggest to buy a tube-cutter: I've bought a small one, suitable for tubes from about 0.5 to 2.2 cm, and it costs me only 2 € (less than 1.5 $). If you don't know how to use a tube-cutter and you cannot figure out by yourself feel free to ask.
The caliber will allow you to make more precise measurements, but you can use a measuring tape with a sign every millimeter without loosing too much tuning. Only a really good ear can sense a difference of a few cents. If you have access to a printer that can use large formats (at least 35 cm on one side), you can print out a schematic with precise measures made with any CAD software. This is my favourite method, but this time I cannot follow this way because my printer is incapable of such dimensions.
The tuner (or a good trained ear) can be useful to test each tube once cut and cleaned. It shouldn't be necessary, but it's a further warranty.
For finishing (optional):
- sandpaper of various grit
- a Dremel-like tool (optional but very useful)
- a lot of patience, a googolplex tons of patience if you want to do everything by hand
STEP 4: Measuring and Cutting
We need 13 tubes with various length, from slightly more than 15 cm to slightly less than 32.
To optimize the space and to use only three 1 m pipes, we will cut each pipe as follow:
1st pipe: 31.69 cm + 29.91 cm + 22.41 cm + 15.84 cm (low C + C#/Db + F#/Gb + high C, about 2 mm left)
2nd pipe: 28.23 cm + 26.65 cm + 25.15 cm + 19.96 cm (D + D#/Eb + E + G#/Ab, almost nothing left)
3rd pipe: 23.74 cm + 21.15 cm + 18.84 cm + 17.78 cm + 16.79 cm (F + G + A +A#/Bb + B, less than 2 cm left)
As you can see, I wrote also the note corresponding to each section. Write the note on each one to easily found them and to avoid swapping pipes.
If you use an handsaw make sure it can cut the material or you will be ruining it. Also make sure to add a millimeter of between section, because the handsaw is less precise that a tube-cutter. If you have a tube-cutter, try to put it with the blade exactly where it should go and use a working glove to turn the knob: it's very tough.
If you cannot print a life-size plan or you don't have a caliber with a tolerance of 0.01 (and big enough to measure 32 cm), you can round to the first decimal digit, but make sure to round properly (for example, 31.69 will become 31.7, 29.91 will become 29.9. The general rule is: if the discarded part starts with a digit less than 5 then you left all unchanged; if it starts with a digit greater or equal than 5, then add 1 to the last digit of the remaining part).
The best way to cut the tube almost exactly (unless you use the printer) is to measure only one section and cut, then measure the next one and cut, and so on.
Every time you cut a piece of pipe, file down all burrs, inside with a rounded needle file, and outside with a flat side. File also the section to make it planar, especially if you use an handsaw.
STEP 5: Cleaning (optional)
I've brought aluminium pipes (light and good-looking), but they have a paint I don't like. For another project (a tin whistle) I've started to sand them by hand with a medium grit sandpaper. How boring!!!
With a Dremel tool you can speed up the process, unless you prefer doing it by hand, but be aware that you will change the sandpaper bit many, many times.
This time, since the whistle was less than 40 cm long and the sum of lengths now is more than 295 cm, I've decided not to sand it. Maybe I will decorate my pan pipes in another way.
So, the image of this step is from my previous instrument, a six-holed pennywhistle made of aluminium, wood (juniper), and electrician tape. I'm very sorry that I haven't take any picture... Maybe I will do another tin whistle, and use the project for another Instructable.
By the way: the tin whistle sounds good, is well tuned, and it's a C-whistle. The next one I will make will be a D-whistle, the traditional Irish tuning for this instrument.
STEP 6: Closing the Tubes
Do you want some more directions? OK, then.
Since the process depends also on what you have choosen as cap, those can be only general directions. I choose to use light cardboard.
File slightly the end surface of the tube to create something the glue will adhere to. Then put some glue on the edge, avoiding the internal of the tube, take a square of cardboard slightly larger than the tube and glue both things together.
When the glue is dry remove the external carboard with a knife, a scalpel or a pair of scissors. With some duct tape, maybe a colored one, cover the edge to avoid any air fugue.
That's all, folks!
Well, for this step...
STEP 7: Putting Everything Together
Take the yarn and wrap 6-7 times around all the tubes, then wrap 2-3 times between tubes (see images). Knot the end when you are done.
Once done the first row, we need the accidentals row. So take the C#/Db and D#/Eb tubes, and follow the same process as before. Then repeat with F#/Gb, G#/Ab and A#/Bb tubes.
Now you should have three partial pan flutes: one with 8 tubes, one with 2 tubes and one with 3 tubes.
Take the 8-tubes and the 2-tubes pan flutes and lye the latter on the first (see first image), lowering the accidentals by 1-2 cm. Try to play some notes. If you hear 2 notes when you play the C, D or E tube, then lower the 2-tubes group. If your nose touches the open end of the C, D or E tube when you try to play a C#/Db or a D#/Eb, then raise the 2-tubes group.
When you find the right place, take a piece of yarn and wrap it around the ends of the first group of five of tubes (C, C#/Db, D, D#/Eb, E). Make 2-3 turn, then knot the end and trim the exceeding yarn. Do the same on the top.
Finally repeat with the 3-tubes pan flute.
You can use some glue to the yarn to fix it in place.
The result of those operations should be similar to the one depicted in the last two images.
STEP 8: Further Improvement: Adding an Higher Octave
But we can take advantage of physics!
OK, maybe there's the need of some other explanations. Two tubes of equal length, but one closed at one end and the other completely open, produce the same note within two adjacent octaves. For example, a closed tube that produce an A4 (440 Hz) is 18.84 cm long. The same tube opened will produce an A5 (880 Hz). We can see this fact from two formulas in the first image.
Actually, an open tube requires a correction factor that depends on frequency and inner diameter, but the difference should be barely noticeable.
So, finding a way to open and close the tubes at wish will give us an extended range: for example, if the original range is C4-C5, the final range will be C4-C6. Without even adding a single tube!
STEP 9: Further Improvements: Adding Another Higher Octave
Again, the answer came from physics. How we can do that? Simple: creating an hole in the tubes.
Wait, don't take your driller too soon. We need some calculation, obviously.
First, if we make a single hole, its size doesn't matter. If you want to add two or more holes for each tube, than the things became complex. So we'll drill only one hole.
We can calculate the distance of the hole center from the open end using the same formula I've shown in previous step (see first image). This time we know the frequency (if you don't then go to the second step). All we need to do is take the frequency of the pipe, double it two times and calculate the value of L. For example, the D4 has a frequency of 293.7 Hz, so the D6 has a frequency of 1174.7 Hz. So the hole center must be 7.06 cm from the open end. If you make a large hole (like 5 mm of diameter), the approximation will be better than a smaller hole.
However, reaching the central tubes with your finger can be difficult, so again finding a way to keep closed all holes and open them simultaneously is a great idea. I'm thinking about the key system of a flute (or sax, or similar systems), but I'm not so good in making such precise works...
This method only works when you can also open the ends, because the note produced is noticeably different if the end is open or closed. This is due to harmonics produced by the section behind the hole. So, the best thing (maybe it's only a dream) is a mechanism that open both ends and holes with a single lever, and only the ends with another lever. This way you can have a pan flute whose range is, for example, C4-C7, three octaves!
STEP 10: Automatic Calculation!
Since it seems there is a shortage of willingness about find out the tubes length on your own (it sounds bitter, right? It's just a pinch of sarcasm…), I made this simple spreadsheet in Google Drive. You can use it "as is", or you can change the speed of sound to a value you think it's more appropriate for you. The numbers should
Before I forget it, here's the link to the awsome
Pan Flute Tubes Length Calculator!Enjoy!
62 Comments
earthshaker77 1 year ago
NitoriousNightshade 2 years ago
caccin.filippo 4 years ago
I also tried a different method to close the tubes: I've cut them a bit longer than required and then I've put some plasticine at the bottom. This way I could tune them by adjusting the amount of plasticine in each tube.
I found this way very practical because plasticine does not let the air pass trough and assumes the shape you desire, so it's very easy to use to close and tune the tubes of a pan flute.
Mukundpune 4 years ago
Taitano 4 years ago
DudesTryingToMakeInstruments 4 years ago
Thanks,
Julian
DeveshT3 5 years ago
Is it possible to get some help from you
My tubes have a diameter of 10mm...I am having difficulties to get the lengths for the notes
Thanks
Devesh
LightspeedDemon 5 years ago
Greetings :) I've been wanting to make a set of panpipes for ages, but had no clue where to begin. Your instructable turned up in a search and after a read I realised it was what I've been chasing. I have two questions. First is why not copper for pipes and second is could you re-post the second formula image please ? part of it got clipped and a symbol is missing. Also, a slightly more detailed explanation of what number gets plugged into which symbol and the relation between the two formulae would be appreciated. :)
Drako84 5 years ago
Hi! I used aluminum instead of copper because it was easier to find the diameter I needed, plus it's lighter than copper so the flute will be lighter too. Anyway, you can use any material you wish, the only difference will be in the timbre (the kind of sound the instrument makes). Regarding the formula, you can just click on it and it will open full-size.
Speaking of the formulas, there are a total of four symbols: the lenght of the pipe L, the speed of sound v, the frequency of the note produced f, and the distance of the note from the central A n, measured in half-tones. The first formula L=v/(4f) can be used to determine the length of the pipe considering the speed of sound in air and the frequency of the note you with to produce. Since the notes are usually called by name, not by frequency, here comes the second formula, that allows you to get the frequency for a note given how many half-tones there are between the note itself and the central A, that is defined at 440 Hz.
Hope this help, feel free to ask more!
Many thanks for the reply and further explanation :) Now I can get to calculating and building... Once complete, I plan to upload a pic of finished panpipes ;)
It did indeed :) Does the correction formula shown somewhere in comments section come into play, or is it a case of minor variations ? Also on a side-note, I found an online free tuner for flutes and similar woodwinds, also works great for fine-tuning panpipes ;) Link is: http://www.flutetunes.com/tuner/
Seems I ran into a snag of some sort when calculating the pipe lengths, I'll work the formula step-by-step for the pipe above the A @ 440, hopefully you can spot my screw-up. First I had to figure out the unit / time for speed of sound which I derived to be 13830 inches / second then worked the formula 13830 / 4 * f, 13830 / 4 * 466.2 . First I worked out the 4 * 466.2, getting 1864.8 then did 13830 / 1864.8, getting 7.416 inches, which is close to the 7.23 inches in your tube length calculator but not close enough. If you can spot my error, please clue me in :)
Drako84 5 years ago
It seems to me that there's no error at all. Probably the difference is due to the fact that the speed you used is slightly different from the one I used. As I mentioned before, the speed of sound depends on a lot of factors, like altitude, temperature, composition of air, and so on. Also, the note emitted depend also by how the pipe is played, and you can adjust the tone by tilting the flute or changing the way you blow on the open end. Hope this helps!
JasiekO 7 years ago
I used to play pan flutes. The semitones could be made by bending the panpipes for about 60 degrees - this makes note sound a semitone lower than normal, so you don't need tube for each tone - 22 tubes is enough :)
I wonder what physics stand by this bending technique. Anybody could help?
LukeH124 7 years ago
So if you look at the general theory, L = v/4f from standard physical principles. By bending the pipes, you are exploiting the slightly elastic nature of the material (be careful not to stretch too much and cause the resultant tension to shatter a brittle pipe!)
When we do this, the elastic properties cause a slight elongation. As you'll notice the frequency is inversely proportional to the length of the pipe. By making it fractionally longer, you slightly decrease the frequency :)
You should also notice that this is a fractional dependence w.r.t semitones. So if you were to bend a longer pipe the same amount, the change in pitch would be greater as the frequency change would be the same BUT the fractional change would be larger.
Please check this carefully and don't wear your pipes since although this is a cool representation of wave physics, I don't want you ruining your panflute :)
JasiekO 7 years ago
I'm not sure if I described exactly what I meant. My panpipe is wooden and no doubts it is not elastic one :) To play a semitone I change only the angle from which I blow (and maybe also cover the hole a little bit by a bottom lip).
If you are good player you can go even three tones lower than the basic tone of the pipe. So I would had to bend it very much to do it.
I've noticed that if you have a round bulb with a hole it is possible to play an octave range by just blowing from different angles and making the hole smaller by covering it with your bottom lip.
MiraMartini 7 years ago
Please its very important that I have your name, or at least your sources so i can get their name
Drako84 7 years ago
However, I suppose you're asking for the sources of information about the data and the formulas used. As I clearly state, my main sources are Wikipedia, Google and an old textbook of physics that I used when I was in high school (since then I've sold the textbook, and I don't remember the title; I'm italian, and so it was the book).
There is something I'm missing? Because for as long as I can think about, I don't seem to find a reason to give you my name.
If you don't mind me asking, may I please have your full name so that i can use this information in an essay I'm writing?
Hi, I seem to be having a problem with calculating the length. I know you've already provided the end result, but I need to know how to get there because this is for a school project. Your formula is length (which unit?) = speed of sound (in m/s?)/ 4* frequency (in Hz?)
I keep getting very small results, like .15 for C4, and I think i'm missing something but I can't tell what. Please help me! How can I find the length in centimetres and not get this: length = 345 (my local speed of sound)/ 4*440 = .196
