Homemake Wooden GoKart 2.0
Intro: Homemake Wooden GoKart 2.0
Well, after my first and mostly successful wooden gokart, I decided to build a sturdier and better one. I used the same wheels, engine, axles, and seat from the first one. For specific details on mounting the engine, sprocket, and wheels, visit my first gokart. This is definitely an improvement from the first. For your convenience, I made a 3D Sketchup model. Download it here. The following steps contain pictures from Sketchup. I recommend you use Sketchup to find the exact dimensions.
STEP 1: Step One
Put two 3 1/2" x 1 1/2" x 75" beams 3 1/2" apart.
STEP 2: Step Two
Place a 22" long beam underneath. Do not attach. Next, place a 3 1/2"x3 1/2" in between the long beams. Place a 1/2" thick beam and attach it to the longest two beams. Then, drill down the middle of the 1/2" thick beam through all three layers. Put a bolt Into the and tighten. The bottom beam should pivot.
STEP 3: Step Three
Attach two 15" long beams
STEP 4: Step Four
Attach a 10 1/2" long beam to tilt the seat bottom. Install the seat bottom.
STEP 5: Step Five
Attach the seat back and install a brace. Place the engine on the mount.
STEP 6: Step Six
Attach a beam underneath the engine, and install blocks underneath that on either side. Drill holes through either side for the axle. Insert axle and and attach sprocket to axle or wheel then install wheels.
STEP 7: Step Seven
Do the same for the front. Add blocks, axle, and wheels.
STEP 8: Step Eight
Add a steering lever and throttle. The throttle lever is connected directly to the engine's throttle.
STEP 9: Finished
Hopefully, I have given you a complete tutorial on how to build your own gokart. Some things on the Sketchup version may be slightly different from the real gokart, but the dimensions are accurate.
171 Comments
YohanL 3 years ago
Any chance we can still download the file?
Thanks!
Yo
tseselskyd 9 years ago
This thing is awesome!
I would like to make something like this for my son but pedal powered.
Any thoughts? Ideas? He's 6.
Thanks.
SkaterX13 3 years ago
Shadowwalker2551 9 years ago
Is it possible to make from metal?
joshthecreater 9 years ago
of course but the steering may be a little harsh but would be better be cause less chance of throttle snapping or any piece of the kart
somedude14 4 years ago
Lmccoy1146 8 years ago
ho many cc
ledmusic 5 years ago
_mamanssi 9 years ago
Hi... may I know what type of wood did you used? and are there any other suitable type of woods other than the one that you used?
PhatN17 6 years ago
He used spruce wood
jpatel364 11 years ago
hunter13 11 years ago
anynoumous builder 7 years ago
could you make one by having a lever system that makes the wheels stop as a friction brake?
i put a metal piece by my foot that i can kick so it slows the tires down fast :)
Yonatan24 7 years ago
Isn't there a brake?
bubblesneek 7 years ago
NOPE
baseball458 8 years ago
RiaanN1 8 years ago
HI, what 3d software did you use? Awesome cart by the way
jhansher 8 years ago
Please answer!
On mine the chain ALWAYS falls off right away. I tried my best to align the chain, but nothing is working. Also do you need to attach the drive wheel to the axle, because my drive wheel is just free spinning over the axle.
Thank you very much!!!
