Introduction: Honda FIT LED Rear Pillar Lights Installation
The Honda Fit exploded into the car world as an affordable, reliable, and eco-friendly vehicle that quickly made its name in the industry. The only one issue that people have commented on is that the car has so much back-end with hardly any lights! However, once you remove those useless rear side pillar reflectors and install this additional LED tail lights, the car is upgraded by tenfold. With these LED rear pillar lights, you add whole new dimensions to your Honda Fit for a grand new look.
Step 1:
This is the rear side pillar reflectors you will be replacing.
There are two bolts you need to remove before you can take off the rear side pillar reflectors. Afterwards, you can take off the rear side pillar reflectors.
Step 2:
This depends on the production of your Honda FIT, but some have a push tab that you need to push for lock-in. For any Honda FIT without the hole for this push tab, you can just remove it with a wrench.
Step 3:
Install back the LED rear pillar lights.
Step 4:
Extend the given wires to the existing harness: black to ground, red to tail light, white to brake light.
Step 5:
Afterwards, this rear side pillar reflector becomes an LED tail light with the same style as your existing one.
Test to make sure everything works. Enjoy your Honda FIT LED Rear Pillar Lights!
This is how the LED rear side pillar reflectors look during the day and night.
8 years ago
Excellent!
