Honda Ruckus- Underseat Storage
Intro: Honda Ruckus- Underseat Storage
The Honda Ruckus comes with loads of storage space. However, as it comes from the factory, you either have to strap the stuff in or get a costly enclosure kit. I decided to go on the cheap and make it out of some tree netting from Lowes. (super simple project)
MATERIALS:
green plastic tree netting......$6.97
valspar black plastic paint......4.97
100 8" zip ties (used ~50).......5.66
total... $17.60
The cheapest enclosure specifically for the ruckus is $90 so that ain't bad.
MATERIALS:
total... $17.60
STEP 1: Paint the Stuff
The only color the mesh comes in is green which is pretty lousy. I sprayed it with black plastic paint thinking it would actually stick to the plastic. It mostly does, but scraping it with anything harder than a fingernail takes it off. I think the mesh is made of polyethylene which is pretty waxy slippery stuff. Meh, it's cheap.
STEP 2: Cut and Zip
Now comes the fun... I started with the easy part (the front). Cut a chunk out of the long edge of the mesh that will be slightly oversized so you can trim later. If you cut from the short edge you won't have enough to wrap around the back in one piece.
Zip tie it and trim the little nubbies off so it fits nicely.
STEP 3: Wrap and Zip and Cut and Zip
So now that you have the easy part, it's time to mess with a large unruly piece of nastiness. Hold the long, uncut edge along the bottom frame tube and center it. Hopefully it will reach around to the front. And... if you're more thorough about painting than I was, it will be black the whole way around too. :/
Put a few zip ties at the center on the bottom tube, and continue zipping along the bottom until you get to the bend in the tube. Now's the Zen cutting of the mesh. Cut a little. Zip a little. Repeat. Be sure to pull on the mesh a bit so it won't create puckers as you zip the top half of this piece. The mesh is pretty stiff, so it's usually not a problem.
I did one half and then the other, starting at the bottom on both halves. Zipping and cutting in a continuous loop will likely create puckers when you get close to the end. Hope that makes sense...
STEP 4: Trim and Done
Now trim it all up, and cut off the extra lengths of zip tie. I used a flush cutting wire cutter. You'll need to trim around things like the helmet lock and stuff, but that's obvious when you get there. Revel at your fine work and throw in some stuff. Ride around like a madman and get over 100mpg doing it. Woot. Woot.
I had some mesh left over. Actually most of it. So, I decided to put some over the headlights for style. I dig it.
And a final revision, I trimmed a bit off the center top portion so the frame can still be used as a grip. This is very useful when setting the jack stand. Finally, I think when all the paint comes off and I'm left with nasty green again, I'll crochet some hemp and have a nice organic netting enclosure. Until that time... tally ho!
6 Comments
ruckuslife 14 years ago
RUCKUS UNDERSEAT STORAGE BAG
This bag is movable - fits perfectly on your ruckus - then you can take it with you to class!
dogguitar 14 years ago
killerjackalope 15 years ago
pumpkinson 15 years ago
Nesagwa 15 years ago
