Hosting Your Own Website
Intro: Hosting Your Own Website
It's great to have a website, but most hosting services are outrageously expensive. If you are reading this on the internet, then you can easily host your own website for free! Here's how to do it.
Thanks to sparks4289 for clarifications.
EDIT: If any of you care to see my website, it is at http://173.53.67.217/index.html. It is not quite done yet! By the way, the login scripts on the page are made of the PHP and MySQL from Wampserver, just to show it works.
STEP 1: 2. Preparations
To host your own website, you are going to need to do a few things.
PICTURE 1
Log into your routers web page (this is usually http://198.168.1.1)
PICTURE 2
Find both your real IP(What everyone else uses) and your local IP(only you use this one). Be sure to write both of these numbers down.
PICTURE 1
PICTURE 2
STEP 2: 2. Download the Server Program
To actually HOST the site, you need a good server program. I recommend Wampserver, a program that contains services such as Apache, MySQL, and PHP. First, go to http://www.wampserver.com/en/download.php and click on "Download Wampserver 2.0i" and follow the instructions. When done, click on the task bar icon and you should see a menu like the one in picture 2.
STEP 3: 3. Write the Website's Code
Write your website's code (HTML, PHP, etc.) and place it in the www folder. This can be accessed by clicking on the www directory icon on the task bar menu.
NOTE: This can take a while even if you are skilled in PHP/HTML. Don't expect it to be easy.
STEP 4: 4. Put Online!
Actually putting the website online is the easiest part. Just click on the "Put online" icon in the task bar menu. To find your website at home, type in your 192.168.1.x IP address. To find it anywhere else, type in your xxx.xxx.xx.xxx IP address. Your website will always be up as long as your computer and internet connection are on.
EDIT: In some cases, you will not have a 'static' IP address. This means that your IP will change every time you go online. In this case, you may need to pay your ISP for a static one.
CONGRATULATIONS! You now have a fully functional website!
19 Comments
sparks4289 13 years ago
charlie.nourse 13 years ago
nil123-3 6 years ago
it's really work
hdboys 7 years ago
thank you i will follow your tutorial step by step to host my site thank you.
my hosting site in algeria : http://www.hebergementsitewebalgerie.com/
1wyldaxe2 8 years ago
https://www.ixwebhosting.com/templates/ix/v2/affiliate/clickthru.cgi?id=wyldaxe
robindallaway 9 years ago
hosting packages are really cheap these days far cheaper than buying a computer and running the power, but great explination.
Sorunome 10 years ago
austech 10 years ago
tzq33tdq 11 years ago
xhacks 13 years ago
http://modbotix.com
and a friends site which is under construction rite now
http://smokenpictures.net
also if ur isp blocks port 80 outgoing then u can forward any port from the WAN side to ur Local side (ie. port 1337 to port 80)
schumi23 12 years ago
(And smoken just doesnt load)
xhacks 12 years ago
xhacks 12 years ago
______ 13 years ago
charlie.nourse 12 years ago
RedMeanie 13 years ago
Ranie-K 13 years ago
