Hot Dog Cooker / Solar Oven
Intro: Hot Dog Cooker / Solar Oven
This Hot Dog Cooker / Solar Oven is simple and easy to make. We have had it reach temperatures over 170 degrees Fahrenheit on a cloudless 80 degree day. Today is a pretty cloudy low 80s day and the oven still was over 115 degrees.
STEP 1: Materials
Materials
- Pringles can or other cylindrical container.
- Sharp knife, make sure you can handle a sharp object or ask for help. Kids - ask a responsible adult for help.
- Straight edge, we used a cut piece of aluminum laying around but a ruler would be good.
- Sharpie marker or other marking pen.
- Skewer
- Hot Glue
- Drill / Drill Bit
Optional
Magnet, Plastic Wrap, Tape
STEP 2: Procedure
Empty contents. Fat Cat had no problem eating the chips in our cans to "help" us out.
Using a straight edge draw a rectangle on the side of the can. We used this side because there were lines already.
Use your knife to cut the rectangle out. Save this piece for later.
Using your skewer, poke a hole through the plastic lid.
Take skewer out and put plastic lid on to bottom of can.
Mark can where hole should go on the bottom of the can.
Drill hole with drill in bottom of can.
Put skewer through the lid, the center of can, and the bottom hole.
STEP 3: Stand
Use the rectangle piece we cut out to make a stand. This will help keep the oven from flipping over.
Take the scrap piece and run a bead of hot glue along the center of the piece. Do not put on the shiny side.
Place the scap piece to the can. Try to make sure that when the solar oven is set down that it will be angled at the sun and not straight up or straight forward. We eyeballed it.
If you want to be exact, use a protractor to determine angle. Different parts of the world get different angles of sunlight and an oven angled properly will get more direct sunlight into the oven causing higher temps.
The stand also allows for different angles. Just rotate the can on its side. Experiment with it and you will see.
STEP 4: Extras
We like magnets. So we put a magnet on the bottom of this solar oven. It helps keep it in place and allows for many different angles. We had it hanging on the back of a metal chair out in the yard. Just seemed to be the thing to do lol.
We added plastic wrap to one to keep heat in. We need to experiment to see which oven cooks hotdogs better.
STEP 5: Success?
Today was a very humid day and cloudy. When we brought the oven up from the basement, the thermometer read around 70 F after about 10 min it was up over 115 F. Outside temp was 82 F.
I don't know if that was much of a success but I know on a sunny day we had the thermometer reading over 170 F on an 80 F day.
Remember to keep adjusting / moving can as the sun moves.
162 Comments
brandt e 9 years ago
It heats up great! I used magnets for an adjustable base.
it only got to about 130ºF but I think it can get hotter. I got it so clear by stretching it out with tape
Cats Science Club 9 years ago
Thanks for making and posting!!
How hot did yours get? How did you get your plastic so clear? That is how it should be. Great idea with the magnet!
Klappstuhl 9 years ago
Isn't the heat somewhat bad for the magnets? Just wondering.
capjbadger 9 years ago
You'd have to get them a LOT hotter to hit the Curie point of the magnet to ruin it. :)
sfcyang 2 years ago
turtlewax 2 years ago
AnsgarWright 3 years ago
The amount of sun you capture has a big impact on the results, that is the reason for the 'wings' addition.... The use of glass bottles retains heat better than a plastic film...you might check my temperature results of different things cooked in the Pringles can cooker.
I have a Pinterest board on solar cooking experiments that aims at the cheaper end of solar cooking... mostly improvements on funnel cookers that can be built for $50 or less... with decent results of a couple hundred degrees.
As a school/scouting type project I don't think adding a small jar is too much to add and it does improve results. and one can do away with the stick and poking holes in the top and bottom. I used the extra layer of Pringles can to hold open the reflector wings because they were handy and worked well, one could use other ways, like plain cardboard... the wings need help to hold a focusing shape. You might try both versions and measure results in basically the same sun conditions.
LeslieBarker 3 years ago
Cats Science Club 3 years ago
ethanlikesSTEM 4 years ago
Cats Science Club 4 years ago
KittyA4 5 years ago
Cats Science Club 5 years ago
tavenl0312 5 years ago
how hot does it git
how hot does it have to be outside about 82 diggress
"Today was a very humid day and cloudy. When we
Remember to keep adjusting / moving can as the sun moves."
JeffJ128 5 years ago
i made a solar cooker and it didnt work what do i do need advice
$1,000,000
Could you load a picture? What I have seen with my students is they tend not to aim the opening at the sun. Using the shadow to line up the opening with the sun is one suggestion. I'll have more accurate suggestions when I see it. I hope you get it working.
