Hot Glue Bubbles!
Introduction: Hot Glue Bubbles!
In this Instructable I will show how to make hot glue bubbles!!! The bubbles made are like the bubbles you get from the CD bubble project but with less hassle and simple tools! This is my first Instructable so be sure to leave feed back on how I can Improve them in the future! I haven't seen this method of making bubbles before! I hope you vote for me in the Hot Glue Contest!
Step 1: What You Need...
To make the hot glue bubbles you will need:
A Hot Glue Gun (With extra glue sticks if needed)
Scissors
Wire cutters
And some wire!
Step 2: Step 1:Get Snipping!
First cut an small length of the wire and wrap it once around your finger as in the picture
Step 3: Step 3:Twisty, Twisty!
Then twist the wire so it forms a small loop as in the picture.
Step 4: Step 4:Now the Fun Begins!
Add a liberal amount of hot glue to cover the 'wand'/loop you have just made and make sure it covers the whole thing thinly with no holes,.being careful not to allow it to come into contact with your skin.
Step 5: Step 5:And Blow!!
As this step implies blow at the centre of the wand and the hot glue should form an bubble before your very eyes! Dont be put of if your first few bubbles don't work as you will get better as you try and try!!! Any way hope you enjoy this Instructible and you vote for me in the hot glue contest!
Hot Glue Challenge
Runner Up in the
Hot Glue Challenge
Crafting 101
Crafting 101
Be the First to Share
    • Retro Tech Challenge
    • Pumpkins & Gourds Speed Challenge
    • Lamps and Lighting Contest
    24 Comments
    leh6873
    leh6873
    Reply 1 year ago
    The wire didn't work for me, but I tried using the straw. That got me a bubble, but if I let go of the end, it deflates.
    MuBoks Stuff
    MuBoks Stuff
    Reply 6 years ago on Introduction
    Yes I guess you probably could! If you try it be shore to tell me if it works!!!
    leh6873
    leh6873
    Question 1 year ago on Introduction
    Is there anything that you need to do to seal it or does it pretty much seal itself? I'm getting ready to try this, just waiting for the glue gun to heat up.
    SandyC108
    SandyC108
    Question 2 years ago on Introduction
    Hi I'm wondering if you have any idea how long they will last? Needing a tub full for Halloween prop. Thinking maybe I could spray them with a sealer of some sort?
    Icy Squirrel
    Icy Squirrel
    2 years ago
    I tried it, but couldn't get the glue to stay on the loop enough to fill the hole. I even tried dipping the loop into a pool of hot glue. Any tips?
    Yonatan24
    Yonatan24
    5 years ago
    That is so cool! How did you think of doing this?
    MuBoks Stuff
    MuBoks Stuff
    Reply 5 years ago
    As many scientist do i found this by mistake whilst hot gluing some wires down an blowint t to cool it glue the an bubble formed and tem went on the try an replicate it with is whaere I am now
    grannyjones
    grannyjones
    How hot is the glue when you are blowing the bubble? I did not see safety glasses.
    MuBoks Stuff
    MuBoks Stuff
    Reply 6 years ago
    Sorry for not replying, the glue cools very quickly as its is so thin when the buble is being formed
    pmoraga
    pmoraga
    6 years ago
    Great! first! Instructable!!! I! think! you! need! to! use! more! exclamation! marks! though!!! :D
    nanaverm
    nanaverm
    What are the properties of the hot glue bubbles, once cooled? I assume they would collapse under weight. Could they be suspended from a string? Thanks.
    MuBoks Stuff
    MuBoks Stuff
    The Bubbles are cling film like and and will stick to glass hands etc. however when peeling off often the bubbles break and they go saggy. as for you question about the string It would probably work what i found i is if I left the bubble on the wand and tried to get an strand glue attached to the bubble and let it cool then use it to move the bubble around!
