Introduction: Hot Glue Sculpture
Here I will show you how to use only hot glue and an LED.
You will need...
- Hot Glue
- Foam
- Printer
- 123D
You will need...
- Hot Glue
- Foam
- Printer
- 123D
Step 1: Pre- Plan
Find a model on 123D and change the slice thickness to the thickness of your foam sheet.
Step 2: Print and Cut It Out
Print it out and transfer the shapes to the foam, now cut the foam.
Step 3: Fill Up the Molds
Fill the Molds with the Hot Glue up to the top.
Then stack and glue the slices.
Step 4: Sculpting and Lighting
Heat a Knife and sculpt to your liking.
Now push the tip of the hot glue gun into the bottom and stick the bulb into the hole.
Done!
Done!
