Hotgluing Erasers to an Arduino
Intro: Hotgluing Erasers to an Arduino
The title really says it all. But I have to stretch this out or the article will get rejected, so bear with me here.
STEP 1: Why I Did It
Well last night I was watching an introductory video on Youtube about Arduino and the guy has plastered I don't know exactly what it was, but it was all over the bottom of his board. But he had a good idea when he mentioned 4 rubber feet.
Four rubber feet, where to get four rubber feet?
STEP 2: Erasers Are Rubber!
I have some reloads for a power eraser, so I cut lengths off of it to use as my feet. But I imagine if someone wants to trash a bunch of new pencils those erasers would work just fine too.
STEP 3: Glue the Erasers to the Arduino
I got my hot glue gun good and hot, then I put a spot of glue on each eraser in turn, and stuck it on where a mounting hole is on the board. Put a good glob on the eraser, and push it so it goes up into the hole a little.
STEP 4: Profit!
Now I am secure in the knowledge that my Arduino board has little rubber feet to stand on. Which is better than lying flat on its back I suppose? I am running low on honest to goodness stand offs over here. This is dirt simple to do too.
6 Comments
russ_hensel 8 years ago
Much better to have feet. Putting your circuit down on a wire scrap can end its life. Nice
pfred2 8 years ago
Yes it can. Probably better to just attach the board to an insulated sheet. So far I have gotten away with just feet though. When I build kits I stand those off on insulated sheet. I use hardboard pieces for that. There's something about an Arduino board just sitting there that appeals to me though.
geeksmithing 8 years ago
pfred2 8 years ago
You can. I just happen to have boxes of erasers for my rotary power erasers, so I use those.
kcraske 8 years ago
pfred2 8 years ago
Thanks. Usually I cut a scrap of hard board, drill that out, then use stand offs to hold a board to it. But I am running out of stand offs, and that is a lot of work anyways. The eraser bits keep a board up off a surface, and help keeping it from shorting out.
I bet a disposable pen tube would work good too. Slice that up into little cylinders.
