House Key Switchblade V2
Intro: House Key Switchblade V2
After creating the first house key switchblade out of paper, I was content with the outcome and how well it actually functioned. Now it has been just over two years and I thought that it was about time to revisit and create a new one since the wear and tear was starting to do a number on it.
As with the first version, it was built off an idea where your house key would be placed into a housing (made of card stock paper) and with some kind of push of a button, the key would pop out exposing the teeth of the key.
You will see the design process all the way to the finished product. Hopefully this Instructable will inspire others to design and created their own version.
STEP 1: Materials
- Card stock (I used 110lb heavyweight from Staples)
- Standard printer paper
- Cutting mat
- Hobby knife
- Scissors
- Pencil
- Sharpies
- Protractor
- Metal ruler
- Plastic ruler
- Scotch tape
- Super glue
- Bottle of all purpose white glue
- Tooth picks
- House key
- Regular pen springs or springs with a diameter less than 3.89 mm (May be hard to find the perfect length for them)
- Tiny spring with a diameter less than 2.16 mm (I found this spring inside a portable book light)
STEP 2: Design Process (Layering)
STEP 3: Design Process (Blueprint Set Up)
I put a piece of tape on the back of my house key and place it on a piece of regular printer paper. Then I traced a copy onto the paper, making sure it was as accurate as possible.
With a ruler I mark two points that were in the middle of the traced house key. Using those two points, I drew a vertical line down the middle of the traced house key. This vertical line was used as a starting point in all my blueprints and it made sure that everything was aligned.
STEP 4: Design Process (Blueprint #1)
STEP 5: Design Process (Blueprint #2)
STEP 6: Design Process (Blueprint #3 and #4)
Blueprint #3 had the same mechanism concept as blueprints #1 and #2. It was a little larger and I closed off the sides where the key would sliding through.
In Blueprint #4 I was messing around with a single sided button on this one.
STEP 7: Design Process (Blueprint #5)
A good week of thinking and a couple of new rough sketches, I finally came up with a much simpler and a lot nicer design. It had one push button release mechanism like any real switchblade would have.
STEP 8: Design Process (Blueprint #6)
I thought that this design was good enough to make an attempt at making a working model. But when I took on making a working model, the blueprint still had errors that hindered the build from working. That was as far I got with this design when I realized that the magnet idea wasn't going to work. So I scraped that model and when back to the drawing boards once again.
STEP 9: Design Process (Blueprint #7: Final Design for Version 1)
STEP 10: Design Process (Blueprint #8: Final Design for Version 2)
STEP 11: Build Process I (Part 1)
Here are the files for the blueprint.
STEP 12: Build Process I (Part 2)
There are 8 layers that make up the top section. 3 layers are for covering up the main launch springs as well as giving the top some design/depth. The next 5 layer are needed so there is enough room for the launch springs to moving inside as well as finishing off the sliding release mechanism.
There are 8 layers that make up the mid-section which holds the key and the sliding release mechanism. It also adds more layers that go towards giving enough room for the launch springs.
There are 9 layers that make up the bottom section. 5 layers are needed for the same reasons as the 5 layers in the top section. The last 4 layers are needed to cover up the launch springs. The pieces are gradually getting smaller because I didn't want the working model be blocky. I wanted it to have a tiny curve so that is looked nice and it would feel better when handled in someone's hand.
STEP 13: Build Process I (Part 3)
STEP 14: Build Process I (Part 4)
STEP 15: Build Process I (Part 5)
STEP 16: Build Process I (Part 6)
STEP 17: Build Process II (Part 1)
I started by taking these 5 bottom layers. I took some white glue and spread it all over one layer with a toothpick and stack another layer on top of it. I continued this process with the rest of the 5 layers and put them under a heavy book and let it dry for about 24 hours.
STEP 18: Build Process II (Part 2)
STEP 19: Build Process II (Part 3)
STEP 20: Build Process II (Part 4)
STEP 21: Build Process II (Part 5)
STEP 22: Build Process II (Part 6)
STEP 23: Build Process II (Part 7)
Without gluing it down I used that part to align the cover for the release mechanism. Once that was aligned I super glued it to the rest of the release mechanism. It protects and covers up the tiny spring. I used super glue for this section to ensure that the release mechanism wouldn't break off when in use.
STEP 24: Build Process II (Part 8)
STEP 25: Build Process II (Part 9)
STEP 26: Build Process II (Part 10)
STEP 27: Build Process II (Part 11)
STEP 28: Build Process II (Part 12)
I glued a 0.4 cm strip of card stock around the border cutting openings in the strip for each opening respectively, finishing everything off.
STEP 29: 3D Model
If anyone does decide to print this model out for their house key, check that the measurements of your house key is compatible with this model. If not you might have to modify it a bit.
Also, the model uses regular pen springs (two if the spring isn't long enough) and a tiny spring for the release mechanism.
Note: Data exported in millimeters.
STEP 30: Completion
Thanks,
li.c.reated
72 Comments
Waldo120 10 years ago
She may go running and screaming thinking that you pulled a knife.
LilTex 4 years ago
CreativLiMade 10 years ago
Hyperlinks1 8 years ago
This looks very cool! Does the key have an automatic way to get back in, or do you have to do it manually?
WilliamB142 8 years ago
nerd1701 10 years ago
jcduplessis 10 years ago
zenTaurus 10 years ago
having looked at the balisong too (but not the optimus yet ^_' ) i'd say you're learning and improving a lot. cheers!
shizumadrive 10 years ago
If you could make it with it people would buy them from you.
that said, it's the use of paper that makes this project intriguing . . . . and very appealing!
wayne_t 10 years ago
Wingloader 10 years ago
