Introduction: Houseplant Repotting: Christmas Cactus
About: gardening, gardens, crafting & creating. let's make the world a more beautiful place. eco-centric company inspired by nature & lovin' the great outdoors.
Christmas Cactus (Thanksgiving, Holiday) are long-lasting, attractive succulents. Here's what you need to know about repotting Christmas Cactus including when & how to do it along with the best soil mix to use.
Christmas Cactus, although lovely when blooming, are not only for the holidays. They’re attractive, long-lasting succulent houseplants. I love the foliage and the weeping form they grow into over time. The soil mine was planted in was pulling away from the sides of the grow pot and just looked old.
Step 1: This Is All About Repotting Christmas Cactus Including How and When to Do It, and the Best Soil Mix to Use.
First off, let’s get a bit technical for those of you who geek out on all things plant like me. Christmas Cacti that you see here and in the video are actually Thanksgiving (or Crab) Cactus. They were labeled as a CC when I bought it and that’s how they’re commonly sold in the trade. Nowadays you may see them labeled as Holiday Cactus. Regardless of which one you have, you repot these epiphytic cacti in the same manner.
What’s the difference between Christmas Cactus and Thanksgiving Cactus?
Both the Thanksgiving and the Christmas Cactus fall under the genus Schlumbergera which I learned as Schlumbergia years ago. The Thanksgiving Cactus has little spine-like notches coming off its leaves (just like a crab claw hence that common name) whereas the leaves of the Christmas Cactus are smoother. The Thanksgiving Cactus is timed to flower in November/December whereas it’s December/January for the Christmas Cactus.
Step 2: Best Time for Repotting Christmas Cactus
Soon after your Christmas Cactus blooms is the best time. Mine stopped blooming at the end of December. I did the repotting at the end of March when the weather warmed.
They start to set their buds in September or early October so you want to transplant yours by early August. This way the plant is settled in before that process starts.
Step 3: Soil Mix for Repotting Christmas Cactus
These succulents are epiphytic cacti and differ from the desert cacti that I’m surrounded by here in Tucson. In their natural rainforest habits, Christmas Cacti grow on other plants and rocks; not in the soil.
They are sheltered by the canopies of trees and shrubs and thrive when protected from full, direct sun. They get their nourishment from organic matter leaf matter & debris falling from the plants growing above them. This means they like a very porous mix that also has a lot of richness to it, just like their fellow epiphytes bromeliads & orchids.
I like to do this blend because it’s rich yet drains well. These are organic ingredients I always have on hand because my collection of plants is always growing. You’ll find some alternative mixes listed a few paragraphs below.
Step 4: My Soil Mix Plus Alternative Mixes
1/3 succulent & cactus mix
I’ve been buying a mix from a local source but have just started making my own. Here’s the recipe for DIY succulent & cactus mix in case you want to make your own too: Succulent & Cactus Soil Mix For Pots
Here are online options for succulent & cactus mix: Bonsai Jack (this 1 is very gritty; great for those prone to overwatering!), Hoffman’s (this is more cost effective if you have a lot of succulents but you might have to add pumice or perlite), or Superfly Bonsai (another fast draining 1 like Bonsai Jack which is great for indoor succulents).
1/3 potting soil
I’m partial to Ocean Forest because of its high-quality ingredients. It’s a soilless mix & is enriched with lots of good stuff but also drains well.
1/3 coco coir chips & fiber
I buy mine locally here in Tucson. Here’s a similar product. A few handfuls of compost A few handfuls of worm compost This is my favorite amendment, which I use sparingly because it’s rich. I’m currently using Worm Gold Plus.
A few handfuls of charcoal Charcoal improves the drainage & absorbs impurities & odors. Pumice or perlite up the ante on the drainage factor too. This is optional, like the composts, but I always have them on hand. You can read how I feed my houseplants with worm compost & compost here: How I Feed My Houseplants Naturally With Worm Compost & Compost
Mix alternatives:
  • 1/2 potting soil & 1/2 orchid bark
  • all cymbidium orchid mix
  • 1/2 succulent & cactus mix & 1/2 cymbidium orchid mix
  • 1/2 potting soil & 1/2 coco coir chips
Pot size
Christmas Cactus bloom best when slightly potbound. Mine was in a 6″ grow pot & I planted it into an 8″ pot. I’ve seen older Christmas Cacti planted in relatively small pots & they’re doing just fine. Make sure the pot has at least 1 drain hole.
Step 5: How to Repot Your Christmas Cactus
My Christmas Cactus got severely pruned by the pack rats so I combined it with a new 4″ plant as well as a cutting. So, my repotting process was a bit more detailed than yours will most likely be.
I’ll simplify the process here:
Remove the plant by squeezing the pot &/or cutting around the sides with a dull knife. I loosen the root ball a bit if it’s tight with a gentle massaging. Place desired mix in the bottom of the pot so that the root ball is even with the top. Fill in around the sides with the mix adding in compost if you have it. I topped mine with succulent & cactus mix, compost & worm compost.
How often should you repot Christmas Cactus?
I’ll repot mine in 3-5 years depending on how it’s doing. Remember, they like to grow slightly tight in their pots so only go up 1 pot size.
Step 6: After Care
I moved mine to the covered side patio where it gets indirect yet bright light. I let it settle in for a few days & then gave it a couple of thorough waterings to make sure the mix was moist. It’s warm here in Tucson now (80’s into 90’s) so I’m watering mine every 5-7 days now.
These are epiphytic cacti & differ from the desert cacti that I’m surrounded by here. In their natural rainforest habits, they grow on other plants & rocks; not in soil. Their roots need to breathe.
Give yours a good drink of water, let it all thoroughly drain out of the pot, & let it go dry before you water it again. You don’t want to keep the roots constantly moist or they’ll eventually rot out.
How often should you water your Christmas Cactus?
How often you water depends on your temps, the exposure it’s in & the pot size. Houseplant watering 101 gives you a general idea. I watered my Christmas Cactus growing outdoors in Santa Barbara every week (yes, they do grow outdoors year-round in temperate climates) in the warmer weather & sometimes not at all in the winter, depending on if we had rain or not. Indoors I watered every 2-4 weeks in the cooler months.
Step 7:
Repotting your Christmas Cactus (Thanksgiving, Holiday) is easy to do and I’m sure yours will appreciate some fresh mix. Mine is putting out so much new growth just a few weeks after its repotting. Can’t wait to see the blooms it puts out in fall!
Happy gardening,
Nell
