How 2.0: Make a Solar Cell Phone Charger
Intro: How 2.0: Make a Solar Cell Phone Charger
From http://www.2pointhome.com
A little soldering is all it takes to make this cool little emergency cell phone charger. Keep it in the glove box of your car, in case you ever get stranded in the woods and start to hear banjo music!
You might be able to find the mini solar panels at a store that sells science or electronics equipment; otherwise you can order them online. Please note, you'll also be cutting the wire on the cell phone charger, so make sure it's not the only one you have! You can often find cheap chargers at discount stores like Big Lots -- it doesn't matter if it's AC or car compatible, since you'll only be using the end that plugs in your phone.
MATERIALS:
1 Altoids Tin case
2 Mini Solar Panels (3V 20mA each)
1 Solder (3")
1 Small Heat Shrink Tubing (4")
1 Large Heat Shrink Tubing (4")
1 Double Sided Tape (3")
1oz Flux
1 Solder Iron
1 Heat Gun
1 Wire Stripper
1 cell phone charger
STEP 1: Step1: Cut Wires & Tubing
Take the 2 solar power panels and cut all four wires to about 1" in length. Cut 1/4" of plastic off of the tip of each wire with the wire stripper so copper wires are exposed. This exposed wire is called a 'lead.' Cut the small heat shrink tubing into four equal pieces (1" each). Slide the small heat shrink tubing onto both black wires.
STEP 2: Step 2: Solder Solar Panel Leads
Using a toothpick, paint leads with flux on a red wire from one solar panel, and a black wire from the other solar panel. Put those two leads together, and solder using your piece of solder and the soldering iron.
STEP 3: Step 3: Heat-shrink Tubing
Slide small heat shrink tubing over the leads you just soldered together. Heat the tubing with heat gun just enough for it to shrink.
STEP 4: Step 4: Cut Phone Charger Wire
Cut off the wire from your old charger to about 2.5 feet and strip off 2.5" of outer plastic from the loose end. Cut 1/4" off of each of the inside wires to make leads. Slide the full length of the large heat shrink tubing onto this main wire for later use in Step 6
STEP 5: Step 5: Flux, Solder and Heat-shrink Loose Leads
On your main wire, slide a piece of small heat shrink tubing onto the red wire. Flux all loose leads of main wire as well as the solar panels with the toothpick. Solder red leads from main wire and solar panels together. Repeat with black wires. Slide heat shrink tubings over these soldered leads and use heat gun to shrink.
STEP 6: Step 6: Test Charger
Test the charger by connecting it to a phone under bright light.
STEP 7: Step 7: Heat-shrink Solar Panel Leads
On your main wire, slide large heat shrink tubing over the two soldered leads which connect to the solar panels. Use the heat gun to shrink the tubing.
STEP 8: Step 8: Tape and Close
On the back of the solar panels, cover the two brass rivets with double-sided tape (so they don't make contact with the Altoids tin.) Tape the two solar panels on the inside lid of the tin. Tuck the main wire into the case and close. Go somewhere sunny (Florida is nice) and charge it up!
For more great DIY projects visit: http://www.2pointhome.com
55 Comments
revelation777 4 years ago
Sammyf812 6 years ago
Thank you!
creektilghmank45 6 years ago
already tried inplix guys ?
witmerchewning 6 years ago
yes. it's reallly good
gg4u 6 years ago
Could you explain why doesn't it need an inverter?
30mA solar panels will they charge also a modern smartphone?
higginswinston39 7 years ago
AlenA8 7 years ago
edd71 7 years ago
it was a little hard but i made it
graphixv 7 years ago
Wow, that's a nice little instruction guide for generalized electronics/charging.
What I'd like to do is take some solar cells I have laying around and build a small charger incorporating a battery bank (or buy a premade bank and incorporate that) that way you could charge anytime.
Thanks!
Amithpardhiv 7 years ago
tunde philipt 8 years ago
Tptoye@gmail.com
oluwadara.ogini 7 years ago
are you nigerian?
mgerlick 7 years ago
have you found the instructables to you query? or anyone making clothes out of solar?
Bunk phone you have there
El Barto 2002 7 years ago
Awesome thanks I'm going to use this to make a little diy wind mill phone charger as a test then go full scale with a battery wall or a little thing with batteries in like a backpack with wall outlets so I can use it to plug in like a lamp or a phone charger I'm thinking about it for a science fair project ?
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 20.0px 'Apple Color Emoji'}
BrandonF44 7 years ago
TimV64 7 years ago
Yes, you should manage your current flowing. Otherwise, if it is dark, the battery will drain through the solar panel!
Please read this document to understand how to properly charge your Lithium battery with a solar panel/
http://www.produktinfo.conrad.com/datenblaetter/550000-574999/553893-an-01-en-CONRAD_LERNPAKET_AKKUS___LADETECHNIKEN.pdf
RiteshYadav 8 years ago
can i use 3 , 1.5v solar cell from road marking light which are used to charge 1 NiMH 800mah battery.
Plz reply fast.
TimV64 7 years ago
Yes you could, please look here how to PROPERLY wire a solar panel and add a recharge module on your NiMH
AakibH 8 years ago
