How Do You Get the Powerful Rooting on Any Android Phone Without Losing Security
Intro: How Do You Get the Powerful Rooting on Any Android Phone Without Losing Security
We know very well that getting the powerful rooting on your smartphone enables you to get more options and the ability to do a large number of changes to the system itself, and also run some applications that require these powers. Many users want to do this process on their devices, but are afraid of losing security of the device. So here came the application of "iRoot" to solve this problem!
iRoot makes it easy to access to the root for a wide range of operating system Android devices from version 2.2 to version 4.4, and. This program is also able to overcome the built-in protection devices from some manufacturers, such as Samsung, known from Knox.
In order to obtain the power of root on your machine, without the fear of losing the warranty, you need to download this application, from here. Before you install the software, you need to install applications from third-party sources option. If you choose to do this process through your computer, you must download special computer program, and do the "usb debugging mode" option on your phone. Then, perform the following steps to root Samsung Galaxy S4 or any other phone model.
STEP 1:
1. If you have a device from Samsung protect Knox, then you need to go to the "Settings-> Security -> and the abolition of "activating the lock.
2. Download and run "iRoot" program on the computer
3. Connect your phone to your computer from the USB cable.
4. Make sure your phone is available on the program database. First you need to install the driver on the PC to mak your device recognized by your PC.
5. After connecting your phone to iRoot, click “Root Now” to start the process.
6. The phone will restart, but do not you disconnect from the computer and wait until the end of the process.
Of course you can shortcut all these steps in order to download the application "iRoot" and install it on your phone, and run after you click on the button to Alroot the process.
After the success of the process and get the power of root, the program suggests you apply for the management of the rest of the applications but unfortunately may be in Chinese, and it’s not practical to use. So it is best to install another program named "SuperSU" which is available at Google Play store.
If your process is in the right way, you can get the powerful rooting without carrying out any modifications to the system kernel. Also, you can choose the iRoot apk to root your Android device without computer. The step is quite similar with the above.
