How to Draw Using the Shape Method
Intro: How to Draw Using the Shape Method
Be patient and the more you do it the better it works materials ruler pencil time eraser. I did it in pen so you could see it better but do it in pencil.
STEP 1: Step One
Draw 8 dots each an inch apart USING PENCIL except the last dot which should be half a inch apart from the rest.
STEP 2: Step Two
Draw the head and make the neck about one centimeter above the second dot I forgot to do this so don't forget.
STEP 3: Step Three
Draw the shoulders as big circles under the second dot it might look wire but once your done you can erase the inside lines
STEP 4: Step Four
On top of the fourth line draw two ovals going outward in opposite directions then attach the shoulders and wast with a curved line.
STEP 5: Step Five
Draw the thighs as stretched out foot foot balls and add little circles to the ends those circles are the knees.
STEP 6: Step Six
Draw two more shorter stretched out foot balls with circles at the end forming the lower leg and ankles
STEP 7: Step Seven
Now draw the feet how ever. Now the arms are just like the legs and draw the hands how you like as well.
STEP 8: Step Eight Draw Clothes
Draw clothes and add other stuff
8 Comments
BSGMutha 8 years ago
Want a girl to like you?
Read on for Dr Muthas PROVEN method.
1. Be yourself. pretending to be a certain way to get a girl doesnt work.
2. Treat any woman you meet with respect. This also applies to the following. If you do get the honor of taking her out, be a gentleman. This does include the next day when your buddies are asking how your date went.
3. Be honest with her.
4. Treat her like she is the most important person in the world when you are together.
5. If you tell her your going to do something, DO IT!!! By the same token, if you say your not going to do something, DONT!!!!
6. Be confident. even if your quaking in your boots, dont let it show.
7. Use your sense of humor but dont be a complete jackass.
8. Dont be afraid to strike out. The more you try the easier it gets and the more confident you will be. This will show.
9. Dont give up. If she says no, try again at a later time just dont stalk her. Sometimes she may want you to work for her effection, but sometimes they would rather poke themselves in the eye with a stick instead of going out with you.
10. Again, dont give up. Eventually you will meet the girl thats a perfect fit for you, you will worship her and she will feel the same about you.
hope this helps someone.
GOOD LUCK!!!!!!
mycroftxxx 8 years ago
Being attractive to women requires one of four things: Appearing competent at something useful, appearing confident about your value, appearing to have good prospects for your future, or being attractive.
Of these four, the two easiest methods for standing out are through confidence and competence. Rules 6 and 8 above cover the first perfectly, act confident and don't be afraid to strike out. There is no _one_ person for you out there, so failing to attract the one you have in front of you isn't the end of the world. For the second, it's a matter of finding a hobby that you can practice in public without being annoying. Learning a solo instrument is good for getting girls to approach you once you're capable of playing it well. However, don't let that limit you. Anything that you can do where you can be seen to be in charge of yourself and able to get things done will be attractive to _someone_ who will want to get to know you better. Unless you picked your hobby out of a hat, you will have at least one thing in common with this girl.
Sheldy123 8 years ago
jscriven2 8 years ago
Example "hey, I like those shoes, really matches your outfit, have you had them long?"
BeachsideHank 8 years ago
Hmmm, you're a pretty smooth guy, if I were a chick I'd let you hit on me, although I'd make you buy me several "Vulcan Mind Probes" at the pub. ;-)
Kiteman 8 years ago
A lot of good advice, but it would be much better if you used your own images - get your friends to pose for you - it would be much more popular. Using googled images make it look like clickbait.
mtattoohead 8 years ago
hitz yadav 8 years ago
