Resurfacing Vinyl Records
Intro: Resurfacing Vinyl Records
And Getting Them to Sound Like New Again
Technology has increased exponentially since the dawn of the digital age. That goes for all the supportive technologies attached to the analog music fields as well. If you're reading this, chances are, you own a vinyl record collection or want to transfer GoodWill records over to CD or other digital format.
Scratchy sounding records are probably what your flea market finds will be. Records with long, deep, aggravating scratches are the worst scenario. No amount of cleaning will ever eliminate those ugly noises. Also, no matter how much you clean and scrub those half-century old discs, they never sound as good as they did the first time they came out of the sleeve.
With this Instructable, I'll take you from the very first time I play a GoodWill find of a well-used and abused record (that was actually cracked, something I didn't notice at the store), with deep scratches and decades of dirt from sitting in a torn cover with no sleeve.
You'll hear it as I did after every step as I bring it back to the perfect sounding album it used to be (with the exception of that crack, which is on the run-out, so it shouldn't become an issue).
My resurfacing method is unconventional... Extreme, if you will. But it works... As you will see.
The video is 15 minutes long, so I hope it doesn't bore anyone. I also used a coat hanger around my neck to mount the camera, so be aware of some scenes that gyrate wildly. I'll not be responsible for anyone getting sick on this ride:)
Note: It's now 2016. I've decided to eliminate using the words "sandpaper" and "records" together... Produces a response like fingernails across a blackboard. "Resurfacing" is a better term, so whenever you hear the word "sandpaper", think "resurfacing material" and everything will be OK. I'm still threatening to make a shorter, more professional video. Eventually, I'll make one... Eventually.
5 Comments
AlexanderD13 8 years ago
I have now tried your method and have found it to be bloody useless. You would have to push incredibly hard to take out scratches. I believe these before and after shots were doctored.
pkny09 10 years ago
bfk 10 years ago
MelVic 12 years ago
Mel
bfk 12 years ago
For the video, I used a scrap cut from a hard rubber packing block. A smooth piece of wood, plastic wine cork or similar material should also work. Softer materials than that may compromise the inside of the groove and anything harder could be risky for the vinyl. The record will sound no better if its glossy, but If its important for aesthetic reasons, a paper of micron-sized grit may be a more efficient way to keep the surface polished.
