How to Install the Sea Gull Lighting 14200S LED Recessed Downlight Retrofit Trim
Intro: How to Install the Sea Gull Lighting 14200S LED Recessed Downlight Retrofit Trim
Be sure to visit our website for all of your home improvement needs http://www.build.com/?source=yt_howto
Installing LED lighting can be easy! Follow Brent Holland of Build.com as he takes you through th estep-by-step process of installing the Sea Gull Lighting 14200S LED Recessed Downlight Retrofit Trim.
For more information on this specific product; check out the product page at: http://www.build.com/sea-gull-lighting-14200s-led-recessed-downlight-retrofit...
LED Recessed Downlight Retrofit Trim Powered by JuiceWorks
Features:
Features (1) 15W Integrated LED Module
ENERGY STAR Qualified for residential use
Easily converts 5" and 6" housing to this low profile design
Quick installation with standard torsion clip mechanism, same as used in most common recessed housings to install trims.
Consumes 15 watts, up to 85% less than incandescent and 40% less than equivalent compact fluorescent lighting
Designed to last 35,000 hours or approximately 20 years under normal use
Dimmable down to 10% using an approved low voltage dimmer
UL / cUL Listed for Dry Locations
Features:
