Introduction: How to Make a Bottle Rocket
It's simpler then it sounds to make a working bottle rocket and doesn't cost you much money. You only need a few materials. Getting the rocket assembled is easy..but getting the parachute to launch is a bit harder.
Step 1: Get Materials
Two 2 litter soda bottles.
A Garbage bag or plastic bag (for the parachute)
Duct tape
scissors
Cardboard or foam core
A Tennis ball
Dental floss or string
Step 2: Cut the Bottles
Once you have all your materials get your bottles.
One bottle you're not going to anything to, which will be your bottom bottle that will connect to the launcher.
The other bottle you're going to cut the top so you have the bottom of the bottle.
Put the bottles together (DO NOT TAPE THEM) to make sure they're cut right before you move on.
(The picture is what the bottles should look like after you attach the wings and make the parachute.)
Step 3: Make the Wings
You'll need the bottom bottle, cardboard or foam core, a pair of scissors, duct tape, and if you want a pencil.
Get the cardboard or foam core and cut out a wing that will a good size for the bottle.
Cut out 3-4 wings that are the same in size. If the size is off it will effect how high the rocket launches. You can make them whatever size you want and whatever shape you want.
Once the wings are cut out, tape them onto the sides of the bottom bottle of your rocket so it looks somewhat to the picture. Make sure they're taped around the same height because the wings effect the direction and the height of the rocket.
Step 4: Making the Parachute
Before you finish assembling your rocket you need to make your parachute. You'll need a garbage bag, a tennis ball, scissors, dental floss or string, and a piece of cardboard or foam board.
You can use a garbage bag or a plastic bag. If you use a plastic bag you don't need to cut it but if you use a garbage bag you'll need to cut it so it's smaller, thinner, and it can fit inside your rocket.
Cut your garbage bag so it's in the shape of a circle. You do this by folding it slightly and then cutting it out.
No matter what you use you have to cut about 4-6 small holes so you can tie the string to the bag. Then once the string is tied to the bag you cut a hole in the tennis ball so the string can fit through and get to the other side of the tennis ball. Then make a hole in the piece of cardboard or foam so the string can also get through. This will hold the tennis ball and string in place. Then tie the string so the tennis ball stays attached to the bag.
Step 5: Putting the Rocket Together
Place the bottom part of the bottle on top other bottle. Make sure the bottom part of your rocket has the parachute with the tennis ball inside. DO NOT TAPE THIS PART! You need to have this some what loose so the parachute will come out of the bottle rocket and land on the ground.
Once your rocket is together you are now ready to fill it up, half way, with water and launch it.
54 Comments
8 years ago on Introduction
I like her name because it reminds me of the tv show
Question 2 years ago on Introduction
How do u build it
Question 2 years ago on Step 5
How do I launch the rocket!
3 years ago
this is like if you said "how to draw a rabbit, first draw a circle, then a line. now draw the rest of the rabbit."
Question 3 years ago on Step 4
How do I cut a hole through a dog tennis ball
4 years ago
make this and show it to kids it blows them away, mentally and physical
its great!!;)
Question 5 years ago on Step 5
How are you supposed to launch it?
7 years ago
I have a quick question, I am doing this as a school project and we did a test run today and it turned out ok, but i wanted to make it better. So I found this, but I am just wondering, what is the point of the tennis ball? I am having just a little bit of trouble understanding this
Reply 6 years ago
some schools at certain grades blast water rockets with eggs as cargo. The ball is used for protection for the egg. The whole point is to see which student does not crack their egg.
Reply 7 years ago
It's for the weight, you need some sort of weight to make it I guess more stable
Reply 7 years ago
NO WAY! I'M DOING THIS FOR A SCHOOL PROJECT TOO!
6 years ago
goood succ
7 years ago
What are you guys talking about you need to use tissue paper as fins
7 years ago
Hello? It's Me
I've been wondering if after all this time you'ld like to speak
7 years ago
For the top bottle, when you cut the opening off, do you need to tape it?
7 years ago
this is difficult 2 do
7 years ago
sometimes brothers can be an exception.
#fortune kitten
7 years ago on Step 5
how do I launch it?
Reply 7 years ago
same here. didn't know at first.
7 years ago
didn't have duct tape. used regular tape. didn't work this time.
