Introduction: How to Make Crepes
You'll need:
150g (1 cup) plain flour310ml (1 1/4 cups) milk2 eggs20g butter, meltedMelted butter, extra, to grease
Step 1 Sift the flour into a bowl. Make a well in the centre. Whisk in the milk and eggs. Stir in the butter. Don't overwork the batter as this can result in tough crepes. Cover and place in the fridge for 1 hour to rest. This helps to create light crepes. The mixture should be smooth, like cream.
Step 2 Heat a little extra butter in a non-stick frying pan over medium heat until foaming. If the pan is not hot enough, the crepe may stick, and if the pan sizzles loudly when adding the batter, it is too hot. Add enough batter to thinly coat the base, and tilt the pan to create an even thickness.
Step 3 If the pan is at the correct temperature, it should take just a minute before the edge curls and the base turns golden. Use a spatula to check it - the base should be golden, lacy and thin enough to see through. Flip and cook for a further minute before transferring to a plate.
7 years ago on Introduction
That is definitely a creative cooking tutorial.
