How to Make Music Nails
Intro: How to Make Music Nails
STEP 1: Gather Materials
You will need:
1)two different colors of nail polish (I suggest white/VERY light pink and light purple)
2)nail polish remover (I suggest one with 100% acetone, it will take the nail polish off 5x faster)
3)music sheet music
4)cotton balls
5)copier/printer
6)rubbing alcohol
7)a bowl
8)scissors
9)a nail filer
10)a clear coat of nail polish
STEP 2: Copy Your Sheet Music
Copy your sheet music and print it out. I would show you how, but you most likely have a different printer/copier than me. :(
STEP 3: Prepare Nails
Wash and file nails, and if you want, apply a base coat to your nails.
STEP 4: Apply Color Coat to Nails
Apply about 3 coats of nail polish to your nails. If you want, paint your thumb, index finger, middle finger and pinkie light purple, and your ring finger light pink.
STEP 5: Cut Out Music Notes
While you are waiting for your nails to dry, cut out the music you want on your nails.
STEP 6: Paste Sheet Music Onto Nails
Carefully poor the rubbing alcohol into your bowl. The place the sheet music on your nails and soak a cotton ball in rubbing alcohol. Rub the alcohol onto the sheet music while it is RIGHT SIDE DOWN on your nails. Hold the paper in place for a couple minutes then gently peel it off. You may mess up a few times, but that's ok. Just paint over the nail and retry after it dries. Good luck!!!
4 Comments
theimpossiblegirl_1 10 years ago
iamKENZiE 10 years ago
crazyrae513 10 years ago
