How to Make Rivets Out of Nails
Intro: How to Make Rivets Out of Nails
This is how to make rivets out of nails. In the photo you can see them being used on a hatchet. These are easy to make and are pretty cheap.
STEP 1: What You Need
You need
-thick nails
-a hammer
-a hacksaw
-a drill and drill bits as big as the nails
-something to use it on
STEP 2: Drilling
Drill a hole through whatever you will use it on that is as wide as the nail
STEP 3: Measuring
Now you need to put a nail through the hole. Make a mark with a sharpie on the nail that is about 1/8 of an inch from the wood.
STEP 4: Cut the Nail
Cut the nail at the mark you made with a hacksaw.
STEP 5: Finishing
Put the nail through the hole again. Then hit the end until it mushrooms out and you can't pull the nail out. Make sure the nail doesn't bend. You could smooth it down until it is shiny, but I like the way it looks now
STEP 6: Applications
I have used rivets like these in many projects. One of my other instructables used it to hold a hatchet head to the handle and it worked perfectly. I have also used it to make knives.
24 Comments
crogshockey 9 years ago
Brass/Copper would look as nice or nicer than a Nail but It's a Very neat idea….Ever thought to use the Tinners riveting tools to set the rivet & then round the other side ? Seems tht a Nail would be almost the same O.D as a Tinners rivet would'nt it ?
Kennethhackneyr97 9 years ago
Thanks, Krinkov. It is useful to know that.
gazumpglue 10 years ago
You are both right. They are made of soft steel but they are also hard. The process of making them work hardens the nails. Just heat them up an let them cool in the air and they will be soft again.
chimplost 10 years ago
Good idea,
regaltaxlaw 10 years ago
sk8er6 10 years ago
DanW13 10 years ago
clickworried 10 years ago
My Diet Area 10 years ago
rimar2000 11 years ago
Krinkov 11 years ago
DTOM_Bear 11 years ago
enfieldbullet 11 years ago
nail steel is pretty soft, usually similar to 1010 or 1020 steel, it won't take temper and is fairly easy to cold work.
i disagree with rimar2000, i don't think you MUST use soft metals and it will weaken some constructions. this is what they did in the past (the presented method).
pop rivets do have aluminium body, but different application all together.
I think nails are made of harder than 1020 steel, but I have not a way to verify that.
Here in Brazil standards provided by Gerdau, the biggest steel company around, says that the steel used for nail manufacture is from 1008 to 1020. can't find more info on ISO or ICS though, a lot about other wires but not so much for nails.
there are hardened nails, but these are not common and cost more.
also we must consider that for ductility, which is needed in the nail making process, you want a low carbon content steel. also, if the nail comes under stress you want it to bend rather than break, which would also agree with lower carbon steel.
I insist that nails may be used as rivets for emergency cases, but they are usually too harsh. Surely making them a softening by heat are most appropriate.
I gave away my old armor when I left the SCA. I still like messing around making stuff just for the heck of it though. This was my latest project, a couple of months ago: Mitten Gauntlets
http://www.bussjaeger.org/gauntlets-mitten-web.jpg
These are pretty crude because I just got bored one evening and whipped them out in a couple of hours from scrap laying around. Didn't even use a proper pattern; just eyeballed it. Never got around to cleaning them up or mounting the straps and gloves. All the rivets started life as roofing nails (prepped as described: annealed, then clipped).
There're a few more how-to type articles on my site. Spangenhelm. Medieval shoes. Hand-made paper. Inks and pigments. Sundials. Mead. Other assorted stuff. (Lots of SCA anecdotal material.) I used to be active in the Society for Creative Anachronism (SCA), so a lot of it is written from that perspective, and for that market.
my next in line is a mongolian bow, i'm still gathering all the materials first though.
had a few laughs reading through your site! cheers!
