How to Make the Letters N and a Out of PVC Pipe
Introduction: How to Make the Letters N and a Out of PVC Pipe
In this instuctable, you will learn how to make the letters N and A out of 1/2 inch PVC Pipe and Fittings.
Step 1: Letter N
Materials:
-Two 90 Degree Elbows
-Two 45 Degree Elbows
-Two 1 Inch PVC Pipes
-Two 5 Inch PVC Pipes
-One 6 Inch PVC Pipe
Step 2: Building the Elbows
Using the 1 Inch PVC Pipe, connect one of the 90 Degree Elbows to one of the 45 Degree Elbows.
Repeat this step with the other set of pipe and elbows.
Step 3: Connecting the Elbows
Use the 6 Inch PVC Pipe to connect the two 45 Degree Elbows together.
Step 4: Creating the N
Lastly, connect the two 5 Inch PVC Pipes to the other ends of the 90 Degree Elbows to create the N shape.
Step 5: Letter A
Materials:
-Two Tee Connectors
-One 90 Degree Elbow
-Four 1 Inch PVC Pipes
-One 2 Inch PVC Pipe
-Two 3 Inch PVC Pipes
Step 6: Assembling the Top of the A
Using the 90 Degree Elbow as the tip, connect the two 45 Degree Elbows using two 1 Inch PVC Pipes.
Step 7: Attachment of the Tees
Once again using the 1 Inch PVC, connect the two Tee PVC Pipes to the 45 Degree Elbows with the side outlet part of the tees facing each other towards the center.
Step 8: Attaching the Center
Insert the 2 Inch PVC Pipe between the two Tee Connectors to close the gap.
Step 9: Add the Legs
Finally, attach the 3 Inch PVC Pipes to the other ends of the Tee Connectors to add the legs of the A.
Be the First to Share
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
