How to PROPERLY Clean Your Bearings
Intro: How to PROPERLY Clean Your Bearings
I see a lot of people who either NEVER clean their bearings, or do it improperly when they DO clean them. I've seen many different ways to clean them, so I thought I would make a standard for cleaning. Here it is, enjoy!
STEP 1: Remove the Bearings
STEP 2: Taking Your Bearings Apart
I used a dental tool to remove the rubber seals from the bearing. If you have a steel bearing cap (see image #3), then look for a little c-clip in the side of the bearing case. If there is no c-clip, then just skip this step.
STEP 3: Cleaning the Bearings
Put the bearings in a container WITH A LID and fill it to the brim with isopropyl alcohol. Cap the container and shake for 5 minutes. If your bearings are still coated in nasty, repeat the process.
Set the bearings out to dry.
While you're waiting for the alcohol to fully evaporate, you can take the time to clean the bearing covers with some paper towels.
STEP 4: Re-Lubricating Your Bearings
If you were able to remove your bearing covers, then get hold of some gel lubricant (picture #1). If you couldn't, then procure some 9-weight gun oil (picture #7).
The rest of the instructions for this step are in the pictures.
STEP 5: Putting Your Wheels Back Together
Another crappy video to tell you how to put your wheels back together.
The best way to work the lubricant in is to RIDE THE BOARD.
15 Comments
MichaelG282 5 years ago
mrtn77 7 years ago
iCounterMyself 7 years ago
Can you make a guide for this? Also, thank you very much for your insight.
JamesB211 8 years ago
Step 1, remove the bearings, step 2, WATCH A VIDEO FROM YOUTUBE
MikeSpax 9 years ago
Isn't that too much lubricant? Or is this just how it goes with grease versus when you're using liquid lubricant?
TheCreative 11 years ago
boardbabe004 9 years ago
traxxer 9 years ago
Great instructable! I use the same Ritalin bearings and never thought of using the bearing container to soak the bearings with isopropyl alcohol.
cbeatty1 10 years ago
Giesterfarher 11 years ago
And whatever you do, do NOT use compressed air to clean your bearings. If you exceed the bearings rotational rating by spinning it with the air, (As fun as it is, LOL) you disk death and/or dismemberment if the bearing flies apart/explodes.
depotdevoid 11 years ago
Happens that these days I'm a ball bearing salesman, and I have a small piece of advice: don't use isopropyl alcohol to clean the bearings, find some sort of spray or liquid degreaser. In general, isopropyl alcohol is not 100% alcohol, there's a small amount of water in it that is bad for your bearings.
There's no way to keep water out of skateboard bearings completely, but do everything you can to limit it!
Goodluck 11 years ago
Commander Shepard 11 years ago
I did know that the water can be bad, but the reason I use isopropyl alcohol is because you don't have to worry about further clean-up as the alcohol evaporates off of the bearings. Plus, the lubricant I use has a water-propellant property (the water will actually be forced out of the bearings after about 5 minutes of riding. I have also been using this system for years without any adverse effect that I can see. However, I DO replace my bearings after about a year or two, so I don't know if that's why.
Thanks so much for reading and replying!
It's a good point about replacing them every year or two, most of the time when I see a bad bearing come over the counter, it's spent several years in service. Also, I deal with industrial application bearings, which see an entirely different service life from skateboard bearings. Skateboard bearings see high shock loads, unsealed exposure to water, twisting in the housing, and high levels of vibration. The same #608 bearings are used in a lot of hand tools and small electric motors, where they can last for years and years without any sort of intervention, but they aren't exposed to anything like the same sort of treatment as the ones used in skateboards.
groybe 11 years ago
Anyway they are crap for cleaning grease and so the dirt in the grease too. I use diesel. You could use kerosene if you are rich.
