How To: Remove Wax Easily
Intro: How To: Remove Wax Easily
Easy steps to help remove candle wax from common items in your home with only a few tools!
Whether you're preparing for a romantic evening, a birthday party, Hanukah, or freshening your home with scented candles, it's likely that you'll end up with some candle wax somewhere. We've all picked at it with fingernails or butter knifes attempting to scrape what little we can off of the surface, usually at the cost of finger nails and the table. This Instructable will walk you through easy steps to safely and effectively remove wax from the most common items in your household.
STEP 1: Hard Surfaces
Candlelit dinners usually lead to some wax dripping and hardening on your nice wooden kitchen table. Luckily it's easy and fast to remove.
Materials:
TIP: I've also read that you can cool the wax by blowing compressed air on it. So if you have compressed air for cleaning your keyboard or something else, feel free to try it instead of an ice cube. I have NOT yet tried this method!
Materials:
- Ice Cube
- Plastic Card (i.e. credit card, library card, etc)
- Ziplock* (optional)
- Remove the candle from the wax puddle gently with your hands.
- Place your ice cube directly on top of your hardened wax. If you are worried about water stains as the ice melts, put your ice cube in a ziplock before placing it on top of the wax.
- Wait for up to 2 minutes.
- Remove the ice cube.
- Take your plastic card, and gently scrape your hardened wax off your wood surface. It should come off within seconds, if it is not replace your ice cube and wait for a longer period of time before trying to scrape up your wax. I use plastic cards so that the risk of scraping your table or surface is minimized.
- Wash with soapy water. If your hard surface is wood, let it dry and then if necessary, refinish with butchers block wax or another wood product.
STEP 2: Carpet
Removing candle wax from carpet is easy. Just gather up the following:
Materials:
Materials:
- Iron
- Paper Towels
- Old Dish Towel
- Place a folded paper towel on top of your hardened candle wax.
- Place an old dish towel on top of the paper towel. This will prevent wax from absorbing through the paper towel and on to your iron.
- Heat your iron to the appropriate temperature for your dish cloth and carpet.
- Run your iron over your dish towel using gentle sweeping motions to avoid burning the towel and carpet.
- Replace the paper towels as they absorb melted wax. A fresh paper towel will continue to absorb wax. If you leave the same paper towel, the wax will continue to melt from the paper towel and spread.
- Once all of the wax has been melted and reabsorbed into your paper towels, you're done!
- If a stain persists after the wax is gone, use your favorite, appropriate carpet cleaner and blot till stain is removed.
STEP 3: Fabric
I've found that table cloths are the most common fabric that runs into candle wax, but aprons, dishtowels and other fabrics are no exception either. Whatever your fabric, as long as it's washable, follow these simple steps to remove wax and potential stains. You are going to combine the methods from step 1 (freezing) and step 2 (heat and iron). We'll remove as much wax as we can with the ice cube method first, to minimize the risk of staining the fabric further. We'll finish with step 2 to remove as much remaining wax as we can by absorbing it. If you are worried at all, please take your fabric to your local cleaners.
Materials:
NOTE: For this step, washable fibers include the following: cotton, linen, modacrylic, nylon, polyester, spandex, and washable wool.
NOTE #2: Darker candles (dark purples, blues, reds, greens, etc) will leave longer lasting and harder to remove stains. At the very least you should be able to lighten it significantly with this method if not get rid of it all together.
Materials:
- Ice Cube
- Plastic Card or A Dull Butter Knife
- Paper towels
- Old Dish Towel
- Iron
- Place an ice cube on top of your wax stain and leave for several minutes. *You could also put the entire fabric item in the freezer, if it is a large stain.
- Scrape the wax with either a plastic card at a 45 degree angle or the back side of the blade of a dull butter knife while pulling the fabric taut. Remove as much of the wax as possible.
- Place a paper towel folded in half on top of and below your wax stain.
- Place your old dish towel on top of the paper towel that is currently on top. This will prevent wax from getting on your iron.
- With a hot iron (temperature set for your particular fabric), make sweeping motions on top of your dish towel. Keep the iron moving so that it doesn't burn your towel.
- Replace paper towels as it absorbs wax. A fresh paper towel will continue to absorb wax. If you leave the same paper towel, the wax will continue to melt from the paper towel and spread.
- Let your fabric dry and send it through the wash!
- If a wax stain persists, or if it was colored wax, use your favorite stain remover appropriate for you fabric and wash again.
STEP 4: Candle Jars
Candles often come in cute little jars that could easily be reused once the waxy residue is gone. Cleaning the jar is easy, let's begin so that you can repurpose it for a variety of other things.
Materials:
Materials:
- Tea Pot/Boiling Water
- Paper Towel
- Boil water in your tea pot or in a pot. I prefer in a tea pot so that it is easy to pour once the water has boiled.
- Place a paper towel under your candle jar. This will catch any overflowing wax or water if you accidentally pour too much into your jar in the next step.
- Pour the boiling water into your candle jar. You will begin to see the candle wax melt and float to the surface.
- Wait for the wax at the surface of the water to cool as well as for the water itself to cool. Then simply remove the wax from the water's surface with your finger (DO NOT DO THIS WHILE THE WATER IS HOT).
- If necessary, repeat this process until all of the wax has been melted and removed.
- You can scrape out any remaining small fragments of wax with a paper towel.
STEP 5: Final Tip
As with most things, preventing melted wax from spilling is the first step to stoping wax stains.
A quick tip to help prevent future wax stains. Fill a glass or bowl or other appropriate candle holder with enough water to surround the candle. If the wax melts and spills over, it will spill into the water where it will cool and harden at the surface. A little water goes a long way!
STEP 6: Done!
You're done! Hopefully this helped you remove wax from wherever you've had it dry recently. So light those candles and enjoy your next romantic evening, birthday, or other celebration.
31 Comments
rwolters7017 4 years ago
NicoleG103 7 years ago
Tory Weiser 10 years ago
How would you get wax off ornate metal (pewter) candlesticks?
Vampyra65 10 years ago
Have you tried putting them in the freezer and picking it off ?
kelleymarie 10 years ago
I agree with Vampyra65! Try sticking the entire candlestick in the freezer to get the wax to harden. Once it's cold, it should come off fairly easily when picked at.
halciber 10 years ago
Nice instructable! Thanks for sharing this with us.
Ice can help remove gum from carpet too and then you pull it up with a fork. To remove gum from hair use lots of peanut butter.
edyshor 10 years ago
I'm also interested on that (removing wax from a bedroom wall) .. don't ask me how it got there :)
ladybgood 10 years ago
instead of putting boiling water in the jar with the wax, put the candle container in a bowl or pot that has boiling water in it. it'll melt the wax no problem and you don't have to avoid boiling water or overflowing wax
Excellent tip ladybgood! Thank you.
AgoVeli 10 years ago
I have a question though. How would you get candle wax off a wall?
btw you should include that in your instructable
elirazk 10 years ago
try to use paper towel and heat blower..
it's work.
bo88y 10 years ago
If the surface is porous, melting the wax with a heat gun will lead to its being soaked in deeper.
I didn't think about it. my walls are flat and sealed.
PhilKE3FL 10 years ago
See my post above about Freeze Mist or Component Cooler.
I'm not sure I've ever had candle wax on a wall! Maybe that would be a good time for the compressed air freezing method? Spray compressed air on the wax till it is frozen. Try to gently scrape off with a plastic card. That would be my first guess at least. I imagine it would also greatly depend on what your wall is made out of and trying to avoid scratching it up.
and7barton 10 years ago
What about removing wax from one's ears ?
bo88y 10 years ago
Try a shovel.
Kaiven 10 years ago
By compressed air, I think that means turning the can upside down so that it freezes the wax. Blowing air on it would just spread liquid wax and wouldn't really cool hard wax that much. Upside down compressed air cans tend to spew out liquid nitrogen or something.
