Introduction: How to Solve the Pocket Cube
In this instructable, I'm going to show you how to solve a pocket cube, or a 2x2. I suggest that you learn to solve the pocket cube before the normal cube, because the normal cube uses the same basic idea.
The first step will show you the notation of the pocket cube. The same notation is used for the normal cube.
Step 1: Learn the Notation
The notation of the 2x2 is very simple.
-The top face is labeled U.
-The front face is labeled F.
-The bottom face is labeled D.
-The left face is labeled L.
-The right face is labeled R.
-The back face is labeled B.
-If a letter is labeled by itself, turn the face clockwise as if you were facing it.
-If a letter is labeled with an ', then turn the face counterclockwise as if you were facing it.
-If a letter is labeled with a 2, turn the face 180 degrees(twice).
-A series of moves is called an algorithm.
-An example of an algorithm: R' D' R D
When you understand this, continue to the next step.
Step 2: Complete First Layer
First, find the white-green-red piece. Find another white piece that has green or red on it and put it under where it is supposed to go.
-If white is on the R face, do R' D' R.
-If white is on the L face, do L D L'.
-If white is on the D face, do R' D2 R D R' D' R
Do this for all of the white pieces until half of your cube is finished.
Step 3: Solve the Cube
Turn the D face so 2 pieces are in the right place. In other words, a piece is where it's supposed to be, but flipped. Look at the cube so the two unsolved pieces are in the F face. Now do F D F' D' R' D' R. Turn the cube upside down and look at the cube so that the F-R-U piece needs to be flipped. Now do R' D' R D until blue is on top. Turn the U face so another piece needs to be flipped. Repeat until your cube is solved!
5 Comments
15 years ago on Step 3
When I use the R'D'RD, it damage my bottom face, why is that .?
Reply 12 years ago on Step 3
It damages it but then if you have done it correctly it will restore the whole cube, it's like a magic algorithm =)
Reply 15 years ago on Introduction
Don't worry about it. Just keep on doing the algorithm, turning the top face to a new corner when needed, and the bottom layer will fix itself.
I can solve the 3x3 cube but until i read this 'ible, i couldn't solve the pocket cube. This is cool. I rate this 5/5 :)
Cool and good Instructable, I wish I had one of these real ones, these are so cool!
