Introduction: How to Squeeze More Out of Your Solar Gadgets
Solar gadgets are useful to have around, especially if you’ve a mind to set up a self-powered system that’s less reliant on the power grid. The sun is, after, a free source of energy if you’ve got the right solar gizmos to work with.
But how exactly can you do more with these solar gizmos? How will you unlock their full potential? Here are some of the more important pointers to keep in mind. See the next step to discover more.
Step 1: Keep the Solar Panels Clear
A thin film of dust won’t kill solar panels, but enough dust or dirt can degrade the efficiency of the panels if they start to block out enough sunlight. A simple moist cloth is all that you need to wipe the panels. Scratches, however, are more problematic – especially for portable solar gadgets. Cover their panels with a clear plastic film that allows sunlight to pass through interrupted. Once the plastic is beat up enough, all you need to do is peel it off the panels and replace it at a later date.
Step 2: Angle the Panels to Face the Sun
If you really want to maximize the efficiency of your solar-powered gadgets, then it will be worth your while to position them so that they face the sun. This will allow the solar panels to soak up as much sunlight as possible, although you will need to regularly reposition your gadgets to “chase” the sun as it moves through the sky.
Step 3: Use Solar Wearables
You would be surprised at how much sunlight your body is exposed to, especially if you spend a lot of time walking around outdoors. Solar vests, solar backpacks, solar hats, even solar umbrellas – these and other solar wearables allow you to harness a respectable amount of electricity as you go about your business during the day. The best part: you don’t need to stop moving to continue gathering solar power.
Step 4: Set Up a Solar Ecosystem
If you expect yourself to spend a long time away from the power grid, like when camping or hiking, then you’ll want to grab solar gadgets that work well with one another. Solar power banks, foldable solar panels, solar tents, solar kettles, solar shower bags – having as many solar-powered gizmos around will ensure that you draw in as much ambient energy as possible.
Step 5: Stock Up Energy With a Power Bank
A power bank is always a good idea to bring around. It allows you to store up energy while you go about during the day; giving you a stockpile of electricity that’ll be ready to use at night. A solar power bank is even better, when you remember the previous bit on setting up a solar ecosystem.
Step 6: Complement Solar With Other Alternative
Sources – one of the best ways to make use of your solar gadgets is to match the up with other gadgets that make use of alternative sources of power. A kinetic generator that hooks up to your bike chain, a thermodynamic generator that transforms heat from a stove or campfire into electricity – these are just two of many other cool gadgets that can help maximize the amount of electricity to complement that which you gain from solar-powered sources.
Keep these tips in mind, and you will be able to make full use of the self-sustaining properties of all sorts of solar gadgets!
In the market for high-quality, low-cost solar gadgets? Visit Chinavasion.com today and check out the gadget wholesaler’s extensive catalogue of solar-powered gizmos, ranging from power banks and foldable panels to backpacks and thermal bags!
