How to Turn a Digital Photo Print Into a Beautiful Painting (using Water!)
Intro: How to Turn a Digital Photo Print Into a Beautiful Painting (using Water!)
These are great ways to decorate your area, give as gifts, or just to try something new on an afternoon.
Using a technique I call "reverse painting", you can use a paintbrush and water on a printed digital photo to manipulate the printed ink for different effects! In particular, you can turn a photo into a beautiful and unique painting.
Compare and contrast the two images shown (a "before" and "after") - make sure to click on the images to view larger versions and see the differences better.
The results shown were obtained with a digital photo print, water, a brush, and the techniques described in the next steps.
STEP 1: Why and How It Works
One day, I noticed that glossy photo paper is a little like the back of a postage stamp. If you wet your fingertip and touch the paper, you will find that it sticks.
Now, while the ink that the photo image consists of isn't necessarily water-soluble, the back-of-postage-stamp binding agent between the paper and the ink is.
This is why we can apply water selectively with a paintbrush to loosen, diffuse, and lift/wash away sections and layers of the printed photo. I call this technique "reverse painting" because instead of painting color onto the paper, you are instead selectively lifting it off and allowing it to remix or reflow (or be removed entirely). You control how this happens with your brush and water.
This process allows you to create beautiful and interesting effects, which I will cover in the next steps.
Note: In my tests, cheap photo paper ("Likon" 20-pack from the 1$ store) seems to work better then the more expensive kinds (such as HP Photo Print).
STEP 2: Some Basic Techniques
Here are some basic "reverse painting" techniques; they show different things you can do with the digital photo print and water. Every technique involves applying water - the difference is all in how it's done.
The basic techniques are: The Eraser, The Smudge, and Sanding.
The images in this step demonstrate these basics. The next step covers applying to entire photos to make them look like paintings.
You can experiment to find your own techniques, too!
STEP 3: Making Photo Prints Look Like Paintings
Using mostly the "Smudge" technique from the previous step, we can loosen, diffuse, and slightly mix adjacent colors on entire images.
Applying more water and being careful to stay in color boundaries (or carefully crossing them), then allowing to dry can give make the photo look like a watercolor painting. I find that it's best to work with a photo that has bright colors, is high-contrast and high-brightness, and is not too busy or "dense" for this effect to be good.
Shown is a lucky cat figurine which has been made to look like a watercolor painting. Also included is the flower from the intro, shown halfway done.
Have fun and don't be afraid to try something new! Fiddle about, and discover your own techniques and share them in the comments, or better yet, make your own Instructable to showcase it!
15 Comments
Elliewolfert 8 years ago
love the idea, thank you for sharing!
WhatAnIdea 9 years ago
Such a cool idea, I was looking for this! The alternative was to get it professionally done (http://bespokeartworks.com/) but I'd rather do it myself if I could :) I'll try this or else get it done professionally!
verdastel 12 years ago
verybluesky 13 years ago
artificially_flavoured 16 years ago
theprojectmaker 16 years ago
Cazza 16 years ago
xxarpian 16 years ago
incorrigible packrat 16 years ago
morCadillac 16 years ago
canida 16 years ago
DotatDabbled 16 years ago
theRIAA 16 years ago
