How to Analyze a BSOD Crash Dump
Intro: How to Analyze a BSOD Crash Dump
Blue screens of death can be caused by a multitude of factors. There are many tools on the internet that can analyze these; however, Microsoft has its own tool. When a computer is exhibiting problems, most users are reluctant to download a 3rd party tool that "might make things worse." This is where the Windows Debugging Tools come into play.
23-12-31Update!Microsoft has made the tool available for download without having to install it as part of a package. WooHoo! This package, according to their documentation, only works with Windows 10/11. I am currently running Linux, so I cant test it. ( side note: If you want to try Linux, id highly recommend this https://fedoraproject.org/spins/kde/ It's a Fedora spin called Plasma. Its a lot like Windows, but its ultra stable and secure out of the box, let me know if you're interested or need help.) I might make a tutorial; however, we are talking about Windows now, here's the link: https://learn.microsoft.com/en-us/windows-hardware/drivers/debugger/Download the tool and continue from Step 4.
This How to Will Instruct a User on How to Install the Tool and How to Analyze a Crash Dump to Determine the Cause.
STEP 1: Download the Debugging Tools for Windows
- Windows 7 and Newer: Navigate to the Windows Dev Center to download the Windows Software Development Kit downloader. This is not the tool, its only the downloader for the tool.
- Windows Vista and XP: Download the Microsoft Windows SDK for Windows 7 and .NET Framework 4 as .NET Framework 4.5 is not supported on Windows XP.
STEP 2: Run the Setup for the SDK
- Click Next through the installer until you reach the screen that downloads the packages, labeled: "Select the features you want to install."
- Deselect all the checkboxes next to all the packages except Debugging tools for Windows
- Click Install.
STEP 3: Wait for the Installer
STEP 4: Run WinDbg
- Run Windbg as administrator. The screenshot is from Windows 8.1, but this step is the same for all Operating systems Vista and higher, run as Administrator.
- On Windows 8.1, this is achieved by searching for the program, then Right Clicking it in the list to the right.
- It is important that Windbg be ran as Administrator.
- On Windows 8 and higher machines, there are permission issues reading crash dumps when the user isn't elevated.
STEP 5: Set the Symbol Path
- Click on File
- Click on Symbol File Path ...
STEP 6: Input the Symbols File Path
- Paste the following text into the Symbol Search Path Dialog
- SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
- Click OK
STEP 7: Save the Workspace
- Click on File
- Click on Save Workspace
STEP 8: Open the Crash Dump
- Click on File
- Click on Open Crash Dump...
- Navigate to: C:\Windows\
- Select the file named MEMORY.DMP
- Click Open
STEP 9: Analyze!
- At the bottom of the wall of text, you will notice a line with the text:
- Probably caused by :
- If you can imagine, thats what caused the BSOD.
- Google the thing that caused your bsod
- For example: In this instance i would google
At the bottom of the block of text, there will be a blue link with the words !analyze -v
- Click on the blue link named !analyze -v
- This will give a further detailed analysis to post on a forum, or send to someone else.
- It will also tell you what kind of fault it was, in this instance, my bsod was a
- DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
STEP 10: Optional: Save the Output
- Click on Edit
- Click on Write Window Text to File...
- Choose a location that is easy to remember, such as Documents.
- Share the text file with people that can help!
- Done!
28 Comments
thebear1 10 years ago
will this work on windows xp pro sp3
Azerial 10 years ago
All the sequential steps will be the same. The only difference is the GUI will be slightly different, but the package to download will be named the same. (Also you won't need to run as Administrator on Windows XP unless you're a limited user)
Thanks for pointing that out! :)
MattK9 8 years ago
Hi Azerial,
I ran through all of the steps as described. However, when I try to open the Memory.dmp file I get the following message:
"Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
Invalid directory table base value 0x0"
I also get a popup window titled "WinDgb:6.3.9600.17298 AMD64"
The windows says:
"Could not find the C:\\Windows\MEMORY.DMP Dump File, Win32 error 0n1392
The file or directory is corrupted or unreadable."
I'm using Windows 8.1 on a late 2014 Dell XPS 13. I recently reinstalled Windows per Dell customer support's advice. Subsequently, I got a BSOD with a "Bad_Pool_Caller" code.
I really don't have much of an idea where to go from here. I'd appreciate any advice you could offer. Thanks in advance!
TapioV1 2 years ago
Nafaaaaa 8 years ago
xxhayleyemeryxx 3 years ago
Many Thanks in advance.
Hayley
Azerial 3 years ago
zed099 3 years ago
Microsoft (R) Windows Debugger Version 10.0.19041.1 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
************* Path validation summary **************
Response Time (ms) Location
Deferred SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 18362 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 18362.1.amd64fre.19h1_release.190318-1202
Machine Name:
Kernel base = 0xfffff805`59a00000 PsLoadedModuleList = 0xfffff805`59e480f0
Debug session time: Sun Aug 16 09:37:32.398 2020 (UTC + 8:00)
System Uptime: 0 days 0:03:54.092
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
0: kd> !analyze -v
* Bugcheck Analysis *
CRITICAL_PROCESS_DIED (ef)
A critical system process died
Arguments:
Arg1: ffffb38b34b342c0, Process object or thread object
Arg2: 0000000000000000, If this is 0, a process died. If this is 1, a thread died.
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.Sec
Value: 5
Key : Analysis.DebugAnalysisProvider.CPP
Value: Create: 8007007e on DESKTOP-D7SFLGE
Key : Analysis.DebugData
Value: CreateObject
Key : Analysis.DebugModel
Value: CreateObject
Key : Analysis.Elapsed.Sec
Value: 40
Key : Analysis.Memory.CommitPeak.Mb
Value: 81
Key : Analysis.System
Value: CreateObject
BUGCHECK_CODE: ef
BUGCHECK_P1: ffffb38b34b342c0
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
PROCESS_NAME: svchost.exe
CRITICAL_PROCESS: svchost.exe
EXCEPTION_RECORD: ffffb38b34b34880 -- (.exr 0xffffb38b34b34880)
ExceptionAddress: 0000000000000000
ExceptionCode: 00000000
ExceptionFlags: 00000000
NumberParameters: 0
ERROR_CODE: (NTSTATUS) 0x34b6d240 - <Unable to get error code text>
EXCEPTION_STR: 0x0
SYMBOL_NAME: ntdll!RtlVirtualUnwind+33
MODULE_NAME: ntdll
IMAGE_NAME: ntdll.dll
STACK_COMMAND: .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET: 33
FAILURE_BUCKET_ID: 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_34b6d240_ntdll!RtlVirtualUnwind
OS_VERSION: 10.0.18362.1
BUILDLAB_STR: 19h1_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c5f11e70-fc8e-2563-6c6f-c30a939b0290}
Followup: MachineOwner
0: kd> !analyze -v
Arguments:
Debugging Details:
Value: 3
Value: CreateObject
Value: CreateObject
Value: 3
Value: 89
Value: CreateObject
BUGCHECK_CODE: ef
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
NumberParameters: 0
EXCEPTION_STR: 0x0
MODULE_NAME: ntdll
OSNAME: Windows 10
0: kd> !analyze -v
Arguments:
Debugging Details:
Value: 3
Value: CreateObject
Value: CreateObject
Value: 3
Value: 91
Value: CreateObject
BUGCHECK_CODE: ef
BUGCHECK_P2: 0
BUGCHECK_P3: 0
BUGCHECK_P4: 0
NumberParameters: 0
EXCEPTION_STR: 0x0
MODULE_NAME: ntdll
OSNAME: Windows 10
Clabbb 4 years ago
e-ferrari 6 years ago
Hi Azerial,
thanks for sharing that. Is it also possible to examine minidumps with that procedure ? I loaded one into the debugger and got:
"Probably caused by : ntkrnlmp.exe ( nt!KiFastFailDispatch+d0 )".
Furthermore (clicking on the link):
"KERNEL_SECURITY_CHECK_FAILURE (139)
A kernel component has corrupted a critical data structure. The corruption
could potentially allow a malicious user to gain control of this machine."
Furthermore:
"Das System hat in dieser Anwendung den berlauf eines stapelbasierten Puffers ermittelt. Dieser berlauf k nnte einem b sartigen Benutzer erm glichen, die Steuerung der Anwendung zu bernehmen." This is german and means s.th. like "It's a stack overflow" (which isn't nice).
Bernd
LeeAnneA 6 years ago
Hi everyone can you please help me analyze the BSOD I'm encountering here. I'm trying to use a serial com port device and upon receiving an incoming file a bsod will appear. I can't replicate the bsod though on my own computer. Thanks for the help.
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffcc003d3227b0, ffffcc003d322708, 0}
*** WARNING: Unable to verify timestamp for nptdrv2.sys
*** ERROR: Module load completed but symbols could not be loaded for nptdrv2.sys
Probably caused by : memory_corruption
Followup: memory_corruption
0: kd> !analyze -v
Arguments:
Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
Arg2: ffffcc003d3227b0, Address of the trap frame for the exception that caused the bugcheck
Arg3: ffffcc003d322708, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
Debugging Details:
TRAP_FRAME: ffffcc003d3227b0 -- (.trap 0xffffcc003d3227b0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=ffffdd0bbf047618 rbx=0000000000000000 rcx=0000000000000003
rdx=ffffdd0bc18eb8a0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80f78ea7cd4 rsp=ffffcc003d322940 rbp=0000000000000000
r8=ffffdd0bc18eb8a0 r9=ffffdd0bc18eb070 r10=0000000000000000
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz ac po nc
nptdrv2+0x7cd4:
fffff80f`78ea7cd4 cd29 int 29h
Resetting default scope
EXCEPTION_RECORD: ffffcc003d322708 -- (.exr 0xffffcc003d322708)
ExceptionAddress: fffff80f78ea7cd4 (nptdrv2+0x0000000000007cd4)
ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
ExceptionFlags: 00000001
NumberParameters: 1
Parameter[0]: 0000000000000003
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x139
PROCESS_NAME: ORiON Virtual
CURRENT_IRQL: 2
ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
EXCEPTION_PARAMETER1: 0000000000000003
EXCEPTION_STR: 0x0
LAST_CONTROL_TRANSFER: from fffff8018797b8a9 to fffff801879704c0
STACK_TEXT:
ffffcc00`3d322488 fffff801`8797b8a9 : 00000000`00000139 00000000`00000003 ffffcc00`3d3227b0 ffffcc00`3d322708 : nt!KeBugCheckEx
ffffcc00`3d322490 fffff801`8797bc10 : ffffdd0b`c53d0c20 ffffdd0b`c50ddef0 ffffdd0b`c514eae0 fffff801`00000000 : nt!KiBugCheckDispatch+0x69
ffffcc00`3d3225d0 fffff801`8797abf7 : 00000000`00000000 00000000`00000000 00000000`00000005 ffffdd0b`c18eb1c0 : nt!KiFastFailDispatch+0xd0
ffffcc00`3d3227b0 fffff80f`78ea7cd4 : 00000000`00000070 00000000`00000000 00000000`00000002 ffffdd0b`c4aed230 : nt!KiRaiseSecurityCheckFailure+0xf7
ffffcc00`3d322940 00000000`00000070 : 00000000`00000000 00000000`00000002 ffffdd0b`c4aed230 ffffdd0b`c18eb9d8 : nptdrv2+0x7cd4
ffffcc00`3d322948 00000000`00000000 : 00000000`00000002 ffffdd0b`c4aed230 ffffdd0b`c18eb9d8 fffff80f`78ea9f88 : 0x70
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
fffff80187a84383-fffff80187a84385 3 bytes - nt!ExFreePoolWithTag+363
[ 40 fb f6:80 43 87 ]
3 errors : !nt (fffff80187a84383-fffff80187a84385)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: LARGE
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
JochemJ1 8 years ago
thanks!!!
SandeepA8 8 years ago
Thanks.
BattulgaB1 8 years ago
Dear Azerial,
Thank you for your valuable information, It's very clear. I've successfully install the debugging tools.
When I following your guideline just faced following information. What does it mean ?
How to understand that messages ? It has any other commands ?
Microsoft (R) Windows Debugger Version 6.3.9600.17336 AMD64
Loading Dump File [F:\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Windows 7 Kernel Version 7601 (Service Pack 1) MP (40 procs) Free x64
Product: Server, suite: TerminalServer DataCenter SingleUserTS
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`01810000 PsLoadedModuleList = 0xfffff800`01a53670
Debug session time: Tue Jun 30 15:16:55.617 2015 (UTC + 9:00)
System Uptime: 0 days 6:48:24.546
PEB is paged out (Peb.Ldr = 000007ff`fffd5018). Type ".hh dbgerr001" for details
BugCheck 1A, {41201, fffff68000125000, 7f87312b, fffffa8067073a40}
Page 625d2f not present in the dump file. Type ".hh dbgerr004" for details
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+13702 )
DuaneW1 9 years ago
iv'e added the debugging tool to the firewall, and for some reason i still cant seem find memory.dmp . im running windows 8.1
AnilG4 9 years ago
jonathanj4 9 years ago
Hello! just found this post and I am going to try it out now
I will be back if it didnt work x)
Azerial 9 years ago
I will work if you follow the instructions :) The hard part if what do you do after you figure out what causes it!
dwightwalker 9 years ago
Many thanks. This solved a random graphics driver crash on Windows 8.1 atikmpag.sys from AMD. Before that I tried changing antivirus but crash kept coming with fuzzy message (graphic card screwed up) so I could not read crash message. Opening MEMORY.DMP with Windbg had there in clear letters the name of the driver above. Old laptop with old driver. I tried AMD Catalyst Omega driver with High Performance Power and am hoping this will fix it. Otherwise frustrating that graphics card is not easily fixable.
Azerial 9 years ago
You might try using an older version of the driver. I dont know much about amd drivers, but i wonder if you can figure out in what version it was that they changed that module and go one version before that. Might just be trial and error.
