How to Brew the Perfect Cup of Coffee
Intro: How to Brew the Perfect Cup of Coffee
This is a step by step instruction on how to make the perfect cup of coffee at home. I know we all make coffee but if you follow these steps your coffee will taste much much better.
STEP 1: Clean Your Coffee Maker
You Think it's clean but it's not! clean it again
Build-up Coffee
Oil, makes future cups bitter and rancid
STEP 2: Use Freshly Roasted Coffee
Fresh-roasted coffee is essential to a quality cup so buy your coffee in SMALL AMOUNTS check out this coffee subscription box
STEP 3: Grind It Like a Boss
Always grind your beans as close to the brew time as possible burr or mill grinder is best because the coffee is ground to a consistent size The size of the grind is HUGELY important If your coffee taste bitter, the grind is too fine If your coffee taste flat, the grind might be too coarse.
For the best result use a burr grinder and not a blade grinder. Blade grinders burn the beans in the process while burr grinders crash them without burning them. I recommend using Bodum Bistro Electric Burr Coffee Grinder
STEP 4: Add Water
Use filtered or bottled water if your tap water is not good or has a strong odor or taste maintain a water temperature
between 195 to 205 degrees Fahrenheit for optimal extraction.
Colder water will result in flat, under-extracted coffee, while water that is too hot will also cause a loss of quality in the taste of the coffee
4 Comments
YasarP 7 years ago
Great video, loved it. A perfect cup of coffee is very important. In fact brewing coffee is a science in it self. I was reading a article the other day "Coffee Brewing: For Dummies" and it went into great detail of the science of coffee. It was a expert guide on brewing coffee for the normal person.
Dankozi713 7 years ago
I started following all these steps just like you laid out and it is truly night and day! My morning cup of coffee is way better and I love the daily ritual of the grinding and boiling.
RickyA27 7 years ago
Swansong 7 years ago
I love coffee!
