How to Build a Robot
Intro: How to Build a Robot
STEP 1: Materials
-(2 )60 tooth gear
-(4) 36 tooth gear
-(6) flat bearing
-(1) controller
-(2) motors
-(4) 50mm wheels
-(11) .318 spacers
-(2) 12" drive shaft
-(10) collars
-(1) battery
-(14) keps nuts
-(18) 8-32x1/2 " screws
-tape
Sled
-(12) keps nut
-(10) .318 spacers
-(5) bearing blocks
-(14) 8-32x1/2" screws
STEP 2: Base
STEP 3: Motors
attach the motors
STEP 4: Bearing Flats
gather 3 bearing flats and 4 keps nuts and attach them towards the front of the rail. Repeat for the other rail
STEP 5: Square Bars
take 2 square bars and push them through the open holes on each bearing flat all the way through.
STEP 6: Outer Gears
place a spacer on the outer square bars, then add a 32 thooth gear next to the spacers on the outer two square bars. repeat for both sides
STEP 7: Middle Gears
On the middle square bar add a 64 tooth bar, then place a small spacer and a collar to stop it off. repeat to both sides
STEP 8: Wheels
on the front square bar, measure 2 inches then add a collar, a 50 mm wheel and another collar. repeat for other side. on the back square bar, add 2 spacers, a 50 mm wheel, and a collar. repeat for both sides
STEP 9: Controller
take 2 screws and 2 keps nuts and screw the outer corners of the controller to the chassis rails
STEP 10: Battery
take a piece of tape and tape the battery to the top of the contoller
STEP 11: Sled
build sled and attach to the robot with tape
STEP 12: Speed
Actual speed of robot: 55.56 cm/s
Theoretical speed of robot: 102.41cm/s
2 Comments
tomatoskins 8 years ago
That looks like a great robot! Thanks for sharing and welcome to the community!
ks12721 8 years ago
Thanks Troy! We are inspired high school engineers and happy to finally be a part of the instructables community!! :)
