How to Bypass BIOS Passwords
Intro: How to Bypass BIOS Passwords
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS
DISCLAIMER
This article is intended for IT Professionals and systems administrators with experience servicing computer hardware. It is not intended for home users, hackers, or computer thieves attempting to crack the password on a stolen PC. Please do not attempt any of these procedures if you are unfamiliar with computer hardware, and please use this information responsibly. LabMice.net is not responsible for the use or misuse of this material, including loss of data, damage to hardware, or personal injury.
Before attempting to bypass the BIOS password on a computer, please take a minute to contact the hardware manufacturer support staff directly and ask for their recommended methods of bypassing the BIOS security. In the event the manufacturer cannot (or will not) help you, there are a number of methods that can be used to bypass or reset the BIOS password yourself. They include:
Using a manufacturers backdoor password to access the BIOS
Use password cracking software
Reset the CMOS using the jumpers or solder beads.
Removing the CMOS battery for at least 10 minutes
Overloading the keyboard buffer
Using a professional service
Please remember that most BIOS passwords do not protect the hard drive, so if you need to recover the data, simply remove the hard drive and install it in an identical system, or configure it as a slave drive in an existing system. The exception to this are laptops, especially IBM Thinkpads, which silently lock the hard drive if the supervisor password is enabled. If the supervisor password is reset without resetting the and hard drive as well, you will be unable to access the data on the drive.
Backdoor passwords
Many BIOS manufacturers have provided backdoor passwords that can be used to access the BIOS setup in the event you have lost your password. These passwords are case sensitive, so you may wish to try a variety of combinations. Keep in mind that the key associated to "_" in the US keyboard corresponds to "?" in some European keyboards. Laptops typically have better BIOS security than desktop systems, and we are not aware of any backdoor passwords that will work with name brand laptops.
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
TOSHIBA BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM APTIVA BIOS
Press both mouse buttons repeatedly during the boot
Password cracking software
The following software can be used to either crack or reset the BIOS on many chipsets. If your PC is locked with a BIOS administrator password that will not allow access to the floppy drive, these utilities may not work. Also, since these utilities do not come from the manufacturer, use them cautiously and at your own risk.
Cmos password recovery tools 3.1
!BIOS (get the how-to article)
RemPass
KILLCMOS
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
Overloading the KeyBoard Buffer
On some older computer systems, you can force the CMOS to enter its setup screen on boot by overloading the keyboard buffer. This can be done by booting with the keyboard or mouse unattached to the systems, or on some systems by hitting the ESC key over 100 times in rapid succession.
Jumping the Solder Beads on the CMOS
It is also possible to reset the CMOS by connecting or "jumping" specific solder beads on the chipset. There are too many chipsets to do a breakdown of which points to jump on individual chipsets, and the location of these solder beads can vary by manufacturer, so please check your computer and motherboard documentation for details. This technique is not recommended for the inexperienced and should be only be used as a "last ditch" effort.
If the manufacturer of the laptop or desktop PC can't or won't reset the BIOS password, you still have the option of using a professional service. Password Crackers, Inc., offers a variety of services for desktop and laptop computers for between $100 and $400. For most of these services, you'll need to provide some type of legitimate proof of ownership. This may be difficult if you've acquired the computer second hand or from an online auction.
DISCLAIMER
Backdoor passwords
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
TOSHIBA BIOS
IBM APTIVA BIOS
RemPass
KILLCMOS
77 Comments
lakshmip001 5 years ago
Jimzon 5 years ago
TonyL195 5 years ago
any help would be appercatied
AlexanderJ54 5 years ago
urmine4209 6 years ago
Riff Flanger plz help me.. I have a dell latitude e6410 apparently it is impossible to find. Service code is GQTPWN1-1F5A please help and thank you so much... you are and hopefully will be a god send to me.. much appreciated ty
etcuts 6 years ago
I have a Toshiba Satellite laptop C75D-A7286 that is bios locked. Any info to reset it would be greatly appreciated.
Lisa allen 6 years ago
Hi, I have a toshiba Satellite S55-B5280 laptop P/N PSPQ2U S/N 6E295904C also locked with a BIOS password, I'm prompt to enter it as soon as it powers on, before I can even log in to windows. Were you able to get the password for your's? If so, can you help me out please, repair shops charge you, MAYBE they get your computer unlocked, maybe the tech guy takes a little cruise through all your personal information while he's got the time and access, I have trust issues when it comes to these things. I would be so thankful for any advice or info you can share, if you found some answers. I'll pay it forward. Thank you~
Greetings and hello; I have a Toshiba Satellite S55-B5280 Part# PSPQ2U-OOSOON S/N6E295904C that's been locked with a BIOS password for about a year. I power it on and when the Toshiba logo screen disappears, there is a black screen with a white box in center it says "Enter Password" then has a long blank box to type it in. And if I do try to type something in the box, nothing actually appears in the box, I can't click on it. Please help, I have opened up the laptop before and tried to find the CMOS battery and jumpers,but everything is too small and I don't have the proper tools or lighting, but I was able to find the CMOS very easily in my old desktop. Please, it's a great computer, nice audio, 12GB memory, 1TB HD it was only used a month or two before it locked us out with the BIOS. It is no longer under warranty so Toshiba can't(won't) help to bypass it. There are dozens of PC repair shops locally, but I don't trust any of them, I'll tell them what's going on, they charge by the hour, then maybe, I quote "maybe" they said, "one of our techs here can take a look at it". Maybe? Yeah, no, I don't trust them. How do I get the correct password for this laptop? I thank you so much in advance for any help anyone can offer~
tdmoran2004 6 years ago
JessicaD166 6 years ago
the service tag is 5WY27Z1 it's a Dell venue 8 pro need a system or administrative password
i have a dell venue 8 pro when i turn on there's a Dell logo then system or administrative password don't know what to do bought it off my brother and he forgot code anyways there's a backdoor I don't have a keyboard for it
jkullmann 6 years ago
Hi, I have a Lenovo W540 that I need the BIOS password for. Can someone please assist? Type 20BG-0016US and serial number R9-0AEFRH. Thank you
Bwanali MwewaE 7 years ago
I hav a dell latitude E4300 service tag JVGLN4J am having trouble i cant do anything with it unless bios password is entered.
please would you so kind to help me with the password.
PhillyP1 7 years ago
System disable [2B4E22A727C27369]
Service tag:5N1N812
BarkatK1 7 years ago
hi, i have Toshiba Satellite Radius 11.6 with bios password. please do you help me how to remove
VanessaP44 7 years ago
Whats the code to unlock the Bios password for my asus x53e date of 2014/04/12
OmerovićM 7 years ago
I have
a dell and I don't know the password
XPS 13 L322X
servicetag BFG7VW1
Shamrock39 7 years ago
Could you please help me with an admin password for a Dell Latitude 6410 laptop. The service tag is 22K0XN1-2A7B. I've tried Dogbert's blog &'related post but to no avail. Thanks for any help or suggestions. Shamrock39
JamesB747 7 years ago
please help me with resetting my dell alienware laptop
startup password
code: 7e909c 78c555 189d
svc tag: 43lryw1
SilasKai 7 years ago
Hi admin please , how can I remove bootup password from Toshiba Tecra A10-15c, it requires password as soon as I press the power button
