How to Check How Much Data Used on IPhone 5, 4 AT&T / Verizon
Intro: How to Check How Much Data Used on IPhone 5, 4 AT&T / Verizon
iPhone check data usage guide comes handy to all modern smartphone users. Most mobile operators limit your data and each month you have to either keep an eye on how much data you consume or pay extra fees for each extra GB you used on top of your data allotment. Luckily, there is a detailed tutorial on how to check data usage on iPhone AT&T, Verizon and other networks.
It’s much easier to live when you are able to track data you use. It doesn’t matter if you are locked to Sprint, Verizon, AT&T, T-Mobile or other company. They all have their own limits and iPhone 4 check data usage guide provides you with an accurate picture of your ‘iPhone monthly life.’
STEP 1: Take Your Handset
STEP 2: Go to Settings. This Is the Main Application for Different Changes and Adjustments on Apple ‘fruit’ Devices.
STEP 3: Go to Settings. This Is the Main Application for Different Changes and Adjustments on Apple ‘fruit’ Devices
If you are running iOS 8 or iOS 7 firmware version you should select Cellular menu.
Users who are still on iOS 6 should choose General menu and go to Usage – Cellular usage.
STEP 4: It Is Now Time to Scroll Down Until You Get to Cellular Data Usage Details. Please Note That the Data You See Might Not Be Accurate
STEP 5: To Get Accurate Information About Your Data Usage on IPhone You Are Required to Reset Data Usage Stats. It Is Best to Do This Every New Billing Cycle You Are Running. This Is Very Simple. Go Down Through Scrolling and Click on Reset Option
STEP 6: You Should Now See How Much Data You Used; However, This Information Does Not Show Your Limits So It Is Better to Recheck Your Data Package Information
STEP 7: Fast Way to Get Your AT&T IPhone Data Usage Information
There is a faster and more accurate way to get your AT&T iPhone data usage information. You have to dial the following combination: #DATA on your gadget and click Send. AT&T will send you a text message that will show both the amount of data you have used and your limit per month.
STEP 8: It Is Also Possible to Get the Special My AT&T Application and Check Your Data Usage Even Easier and Faster.
STEP 9: How Do I Check My Data Usage on Verizon IPhone?
The steps are the same as for the AT&T model. You can also dial #DATA to get a message from Verizon about your data usage and monthly limit. This mobile company also has My Verizon app you could use for tracking your limits and usage.
STEP 10: Check Iphone Data Usage on Others U.S. Carriers
YouTube video can also help you check how much data used on iPhone AT&T or other carrier.
Other U.S. companies’ subscribers can also follow the instruction above to get information about their iPhone data usage. However, for Sprint and T-Mobile networks you should dial different combinations. For example, T-Mobile users can get details by dialing #WEB# and Sprint customers should dial *4 to listen to their data usage information. It is always better to control everything when you don’t have unlimited data plan with your mobile operator.
