How to Check the Revision Level of Your ESP32
Intro: How to Check the Revision Level of Your ESP32
Up till now, Espressif released two chip revisions: Last September Rev 0 and in February, Rev 1. And there are rumors, that Espressif sells its old revision 0 chips cheap, and some of our manufacturers make a profit by selling them to us… So, let’s check!
STEP 1: Watch the Video
First watch the video inf you want the details.
The revision number is stored in an eFuse on the chip. Many other parameters are also “programmed” in these eFuse blocks.
STEP 2: The Fuses...
What is a fuse in a microcontroller? Fuses are usually bits which can be set only once. This is, why sometimes people talk about “burning” fuses, not “programming” fuses. They are used to store data, which is chip-specific, but not the same for all chips. The MAC address is an example. Each chip has a different MAC address, and it keeps it till the end of life. So, during manufacturing, this address is “burned” into the fuses block.
And the warning in the ESP32 documentation is clear: You cannot undo this step! Different than with our ATTinys, where we still had a chance to undo the change with a special programmer using 12 volt programming voltage.
But today, we do not want to change a fuse, just read its content. So, no danger.
STEP 3: How to Extract the Revision Number
The revision information is in EFUSE_BLK0_RDATA3_REG
at the 16th place. The proposed formula to read the information is rather complicated: We read the whole register, shift it to the right by 12 places, and OR it with the number 7. The easier solution could be to just shift it to the right by 15 places. Then, the revision bit would stand at the last digit. Maybe Espressif has a particular numbering scheme in mind for the future. Who cares. We know, how we get the information. And here it is:
STEP 4: The Sketch
After testing my boards, I can confirm,
that two boards from last year were, obviously, revision 0. Most of the ones bought over the last few months were revision one. The only exception was this part purchased from Aliexpress. So, I cannot confirm, that sellers still ship cheap old versions. At least not mine. Mostly fake news!
STEP 5: What Are the Differences?
See the bugs of the different versions on page 2
14 Comments
Gilbert54 2 years ago
https://github.com/husarnet/esp-idf/blob/master/co...
* @brief The structure represents information about the chip
typedef struct {
esp_chip_model_t model; //!< chip model, one of esp_chip_model_t
uint32_t features; //!< bit mask of CHIP_FEATURE_x feature flags
uint8_t cores; //!< number of CPU cores
uint8_t revision; //!< chip revision number
} esp_chip_info_t;
Sample code:
#include <esp_system.h>
esp_chip_info_t chip_info[sizeof(esp_cesp_chip_infohip_info_t)]; // reserve memory for chip information struct
esp_chip_info(chip_info); // get the ESP32 chip information
esp_chip_model_t chip_Model = chip_info->model; // ESP32 chip model
uint8_t chip_Cores = chip_info->cores; // ESP32 nr of cores
uint8_t chip_Revision = chip_info->revision; // ESP32 revision nr
const char * espIdfVersion = esp_get_idf_version(); // get ESP Development Framework version
Kind regards from Belgium
BitSand 3 years ago
You kept it simple but not the above.
Thanks for the work.
Anthony
Edit: Please ignore, I figured it out.
Thanks.
Andreas Spiess 2 years ago
gabrielfaber 2 years ago
H:\projects\arduino\ESP32_version\ESP32_version.ino: In function 'int getChipRevision()':
ESP32_version:12:47: error: 'EFUSE_RD_CHIP_VER_RESERVE_S' was not declared in this scope
return (REG_READ(EFUSE_BLK0_RDATA3_REG) >> (EFUSE_RD_CHIP_VER_RESERVE_S)&&EFUSE_RD_CHIP_VER_RESERVE_V) ;
ESP32_version:12:77: error: 'EFUSE_RD_CHIP_VER_RESERVE_V' was not declared in this scope
Checking the library source, I found the names have changed:
EFUSE_RD_CHIP_VER_REV1_V
and
EFUSE_RD_CHIP_VER_REV1_S
Now it works:
REG_READ(EFUSE_BLK0_RDATA3_REG) 1010000000000000
EFUSE_RD_CHIP_VER_REV1_S 1111
EFUSE_RD_CHIP_VER_REV1_V 1
Chip Revision (official version): 1
Chip Revision from shift Operation 1 (<- had typo, fixed)
jcasalotti 4 years ago
This is an "old" post, and as pointed out by razibu, Arduino IDE now provides the info when uploading every sketch.
But I'm the kind of guy who likes to better understand the "details", so every chunk of info is valuable.
And your posts and videos are really nice, clear, and concise.
Thanks, Guy with the Swiss Accent!
razibu 5 years ago
Rudy Trujillo 6 years ago
What does this mean?
C:\Users\me\Downloads\ESP32_Version\ESP32_Version.ino:8:27: fatal error: soc/efuse_reg.h: No such file or directory
#include "soc/efuse_reg.h"
compilation terminated.
exit status 1
Error compiling for board Generic ESP8266 Module.
ssinst 5 years ago
I also need the answer to this. It seems there is a step missing to set up library paths?
mjrovai 6 years ago
Thanks, Andreas. I wrote a couple of Instructables using a Doit Dev Kit bought at Aliexpress few weeks ago and I confirmed that in my case was version 0. I do not find problems on this version at least with what I have tested so far. I read the document with the bugs and see that I could have problems on some specific tasks.
Andreas Spiess 6 years ago
mjrovai 6 years ago
tytower 6 years ago
Interesting . Thanks for posting this
You are welcome!
