+1-844-355-5111 How to Clear a Paper Jam in HP Laser Printer?
Intro: +1-844-355-5111 How to Clear a Paper Jam in HP Laser Printer?
HP Printers come with world-class printing technology to print documents in various formats. It is generally gives a good quality print and run smoothly without any issue.
However, HP printer can also how a problem and paper jam is one of the most common issues creates problem for end-users. And paper jam like issues trap paper which gives a rough printing and blurring of images.
At this point of time HP printer will stop working and an alert message or light blinks inform you that there is a paper jam.
STEP 1: Find the HP Laser Printer User Guide to Read the Manual Instructions
The user-guide contains all the useful information and instructions to solve paper jam problem with HP printer. However, if you don’t have that user manual, you can find the process discussed below will help you to clear paper.
STEP 2: In User Manual Find the Instructions
In user manual find the instructions, and many HP laser printer provide guided information of paper jam problem with the right solution, you just need to follow the instructions given below.
STEP 3: First You Have to Turn-Off Your HP Printer and Find the Place Where Paper Stuck
This is near fusers but wait till it become at normal touching temperature because it became heat while in use.
STEP 4: Now Open the Printer Door to Access the Paper
Open the door by pulling it and slide the tray that give you the clear view of paper jam area from where you can pull-out paper.
STEP 5: Now Check the Paper Which Is Stuck Inside the Printer
Now check the paper which is stuck inside the printer, when you open it you can see the jammed paper clearly. After pulling the main paper again check for any minor piece of paper inside the tray, toner cartridge and fuser and any other place where there is a possibility of paper jam.
Take hold of handle on the cartridge and gradually pull it out that will allow you to give a look at any paper that jammed around it. Change the cartridge when you cleared the paper and make sure that no more any portion of paper is jammed of it.
STEP 6: Remove the Paper Sheet That Is Jammed Inside the Printer
Remove the paper sheet that is jammed inside the printer, smoothly cling the paper and pull out of the laser printer. While removing the paper always try to pull it in the same direction where printing revolves, pulling is reverse direction can affect the original functionality of HP laser printer.
STEP 7: Now You Can Close the Cover of Printer and Turn on It Again
Now you can close the cover of printer and turn on it again. However, most of the laser printers feature to automatically start and now you can print the document with your HP laser printer. However, if you still have any problem you can call to HP printer technical support +1-844-355-5111 for the expertise help.
