How to Coleman Slide Longboards!
Intro: How to Coleman Slide Longboards!
The Coleman slide, or any longboard slide for that matter, is an important skill needed for going down hill where you might need to stop short (for example, riding on a hill where cars drive).
This instructable covers the Coleman slide which is considered the best first slide by many boarders. After learning this slide, you can move on to many other slides like pendulums, standing slides, and others.
Sub Note: I do not have any pictures of myself sliding, so Instead I have used a picture of the inventor of the Coleman slide, Cliff Coleman.
Image Source: http://www.geocities.com/sk8sanjose/coleman.jpg
STEP 1: What You Will Need:
- Some skateboarding experience: Be able to carve down hills.
- Sliding gloves: 100% necessary, either buy some, or make some using this guide:
Sliding gloves allow you to put your hands on the ground at speed without hurting yourself.
- A board: again, 100% necessary, make one using this guide:
Your trucks should be pretty loose, but not super duper loose. Wheels, although you will hear otherwise, aren't that important, just don't cry if you wreck your soft wheels.
- A helmet: YOU NEED ONE, you might die without one
STEP 2: What Kind of Day to Learn and Where?
When
If you are ok with possibly wrecking your bearings, I strongly recommend a wet day. The wetness will allow you to slide alot easier than when it is dry. Otherwise, dry will work.
Where
Here you have some choices that don't really matter.
It doesn't really matter where you learn as long as you can get up to speed and then have another 15-30 feet of slide room.
Where
- A large flat area
- A semi steep hill
- A hill leading into a parking lot
STEP 3: What to Do:
Set aside a good hour or so to learn. Put your helmet and gloves on, grab your board, and set out.
Get into the box position, and put your hand facing downhill behind you on the ground, and do a large, sharp, and fast heelside carve.
Lean in to your hand, and if you need to do it steez *. Steez is when you grab the board behind your back foot.
Really, what will help your success the most is to get out there and experiment with turns. It is hard to explain in words, so your practice and experimenting will be the most helpful.
- Steez isn't widely recomended, but I can't initiate a slide without it.
STEP 4: Increasing Style:
After you hit a few Colemans, you will want to make your slide look better.
What you need to do is to make sure you slide enough to do a 180. This makes it so you slash your speed in half (or more), and then can ride out of it.
Just mess around and see what works best for you.
STEP 5: Going BIG:
FInd some sick hills, bomb down, then Coleman 180 out, it is so much fun!
Watch out for cars cracks in the road, and other stuff, a helmet is very handy!
Make sure to work your way up to big hills, going all out right after learning can lead to some nasty bails.
I hope my Instructable helped you learn sliding, drop a comment on anything about sliding, I'll do my best to answer!
39 Comments
SkatingP 5 years ago
le_poptart 8 years ago
Elijah0831 9 years ago
So, I tried this yesterday, without success. Whenever I tried initiating the slide, it would throw me off, because the back wheels just wouldn't slip. I was using 70 mm., 78A rounded lip cruising wheels and gloves consisting of a square of brake pad material, and duct tape wrapped around the fingers and palm. It had rained the day before, and the road was still kind of wet. Why didn't it work? Was there not enough grip from my gloves? Was I just going too slow (like 10- 15 mph)? I had the same problems with pendies, btw... Can anyone help?
aryanto.karnali 9 years ago
Zaphod Beeblebrox 14 years ago
shedding245 9 years ago
because hes too good for it
couchpotato130 10 years ago
vanpaun 14 years ago
isaac! 13 years ago
XI3 12 years ago
Franco Laverde 10 years ago
mitchknx 11 years ago
Vitamins3 12 years ago
dreadyzkush 12 years ago
yoyojoeco 11 years ago
chubby8 12 years ago
