How to Connect NodeMCU ESP8266 to MySQL Database
Intro: How to Connect NodeMCU ESP8266 to MySQL Database
MySQL is a widely used relational database management system (RDBMS) that uses structured query language (SQL). At some point, you may want to upload Arduino/NodeMCU sensor data to the MySQL database. In this Instructable, we will see how to connect NodeMCU ESP8266 to the MySQL database.
Here I am going to use 000webhost to host MySQL database because of simplicity and free availability. However, you can use any platform with LAMP (Linux, Apache, MySQL/MariaDB, PHP) stack installed on it. Even you can use XAMPP to host MySQL database locally on your Windows PC.
In this instructable, I am not going to use any sensor. I will just increment two variables and insert them into the database. However, you can connect any sensor with your board.
Requirements:-
- NodeMCU ESP8266 development board
- Free version of 000webhost account (or MySQL installed on localhost)
- Filezilla FTP client (free version)
STEP 1: Create Web Application
- Navigate to 000webhost.com and login to your account.
- Locate Create New Site button on the top right corner of the window.
- Enter desired site name and password and then hit the create button. (Note down site password in a safe place because we are going to use it in upcoming steps).
- Proceed to Manage Website option.
STEP 2: Create MySQL Database
Navigate to Tools >> Database Manager and then create a new database.
After successfully creating the database, proceed to Manage >> PhpMyAdmin.
STEP 3: Create MySQL Database Table
- Locate and click on the database name in the left panel of PhpMyAdmin Window (as shown in screenshot a).
- Enter table name and number of columns (let it be 5). Then hit the Go button.
- Create columns (as per schema shown in screenshot b) and then hit save button.
Alternatively, you can create table by running the below command:-
CREATE TABLE `id13263538_sumodb`.`nodemcu_table` ( `id` INT(10) NOT NULL AUTO_INCREMENT , `val` FLOAT(10) NOT NULL , `val2` FLOAT(10) NOT NULL , `date` DATE NOT NULL , `time` TIME NOT NULL , PRIMARY KEY (`id`)) ENGINE = InnoDB;
STEP 4: Download and Edit PHP Files
- Download dbwrite.php and dbread.php file from Github (or download attached files).
- Update database details and table name in dbwrite.php and dbread.php (as shown in screenshot).
STEP 5: Upload PHP Files to the Server
- Navigate to Manage Website >> Website Settings >> General.
- Note down hostname, username, port and password (password is same as site password created in step1).
- Use these details to connect to the server using Filezilla FTP client (as shown in screenshot).
- Navigate to public_html folder and upload dbwrite.php and dbread.php files.
STEP 6: Edit and Upload Arduino (.ino) File to NodeMCU ESP8266
- Navigate to Manage Website >> Website Settings >> General and note down Website_Name (site URL).
- Edit .ino file to replace example.com with the name of your site. Also don't forget to update WiFi SSID and password.
- Finally, Upload code to NodeMCU.
STEP 7: Check Connection to MySQL Database
Once code is uploaded to NodeMCU, it will start sending data to MySQL database.
Visit "example.com/dbread.php" to view database values.
Hope you find this tutorial helpful. Enjoy!
17 Comments
Md.MuradH 6 months ago
Rishi Rishi 6 months ago
yuminmin494 9 months ago
exit status 1
Compilation error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
Rishi Rishi 9 months ago
With the new board version, there are minor code changes:-
Use this updated code:- https://github.com/TrickSumo/NodeMCU-ESP8266-MySQL...
Will upload updated .ino file here also.
Thanks
sandikalakual 2 years ago
I got this in serial monitor...what should I do?
thesis7080 3 years ago
MdCreater 3 years ago
erkansaglikmain1 3 years ago
muhammadamin831996 3 years ago
mervimervao 3 years ago
Rishi Rishi 3 years ago
Make sure database details are correct in PHP file.
busvenc 3 years ago
Not sure what may be causing problem.....
Is php file accessible from Chrome browser?
busvenc 3 years ago
familylovermommy 4 years ago
Rishi Rishi 4 years ago
