How to Control LEDs With Arduino
Intro: How to Control LEDs With Arduino
So in this tutorial I am going to light some leds with arduino uno board.
STEP 1: Things You Need
Arduino uno
USB 2.0 Cable type
Male to male jumper wires
LEDs
Breadboard
USB 2.0 Cable type
LEDs
Breadboard
STEP 2: Led Explanation
a light-emitting diode (a semiconductor diode which glows when a voltage is applied).
The long side of the led is positive or plus(+) whereas the short side is negative or minus(-).
STEP 3: Setting Things
This is the setup of the project.
Connect the ground(GND) pin of the arduino board to the minus(-) side of the led.
Then connect the plus(+) side of the led to 0 pin of the arduino board(if 0 pin does not work use pin 2).
Connect the arduino board to your computer with USB 2.0 Cable.
(you don't need a resistor as shown in the photo).
STEP 4: The Code
Go to arduino IDE and name your project as led and save it.
Then write the following code.
If you use pin 2 for the (+) side of the led, then just change the number 0 of the code to 2.(pinMode 2 and digitalWrite 2).
STEP 5: Final Result
Now the led will light up if you have used the first code.
If you use the second code the light will blink.
3 Comments
chanidu1214 4 years ago
Penolopy Bulnick 4 years ago
