How to Convert Toyota Camry Turn Signal Lights to LED DRL
25,043
10
Introduction: How to Convert Toyota Camry Turn Signal Lights to LED DRL
About: Everything about automotive LED lights
Have you always wanted those bright LED daytime running lights on your Toyota Camry but don’t want to buy the expensive XLE model to get those? Well now, with our Toyota Camry Switchback LED DRL conversion kit, you can have just that on any model of the Toyota Camry. With only a few simple steps you too can have the LED Daytime Running lights just like the XLE models.
Step 1:
Turn your wheel to the opposite direction of where you are starting. If you are working on the driver hand side, turn your wheel to the right and if when you are working on your passenger side, turn your wheel to the left. This will allow you to access the plastic cover in the wheel base. Remove the pins holding the plastic cover in place to access the turn signal bulb.
Step 2:
Locate the blinker lights and twist and pull to gain access to the OEM incandescent light bulb.
Step 3:
Directly replace the turn signal lights with our Toyota Camry Switchback LED DRL and do the same to the other side.
Step 4:
Connect the driver side and passenger side blinker bulbs by connecting the pigtails wire together.
Step 5:
Once you start your vehicle, this is what your new LED daytime running lights should look like. Bright and very stylish.
Step 6:
Locate the fuse box and look for the ACC relay shown in the picture.
Step 7:
This is where you have to put the wire in. Once the wire is in, put the ACC relay back in its place.
Step 8:
When you are driving around, this is what your new LED daytime running lamps will look like. When the blinkers are on, your new iJDMTOY switchback LED will change to a bright amber color just like the ones shown in these photos.
Step 9:
Now you can enjoy your new brighter Toyota Camry LED DRL Turn Signal Bulb just like the ones you would find in the XLE model. With these installed, you can now enjoy the new look on your car and also be seen from further away making your presence more noticeable than other cars on the road.
Be the First to Share
    • Puzzles Challenge
      Puzzles Challenge
    • CNC and 3D Printing Contest
    • Lamps Challenge
      Lamps Challenge
    RickF50
    RickF50
    6 years ago
    Great appreciation for this excellent show of how to correctly install these bright led's on my new 2017 Camry. Can't wait to get started.
    rickf178
