Introduction: Make Car Floor Mats Fit Perfectly for Your Car
Floor mats are one of the most common yet the most supreme car accessories. It serves too many functions to be ignored at first. Whether it is the fall season or the coldest month of the year car floor mats are something that protects your car in all weather conditions. Well, many people still believe that car floor mats are merely used to keep your feet; however, this is surely a misconception. Car mats do play an important role in magnifying the interior look of your car. Especially for a car owner, the color, style, and design of the mats do make a huge difference.
Do you think that your mats are getting old and worn out? Are you finding the car mats too expensive? Do the mats keep sliding and slithering while you drive because the size of the mats just doesn’t fit right? Or is it just that you do not like the mats that came with your car? Make a style statement with the car mats that are designed perfectly to fit the interiors of your car.
Dirty and grimy mats not only aesthetically look unpleasing but are something you must not overlook. However, driving without car mats is also not the right way to go, as these mats serve to protect your car from mud, water, dust, and stains. Well, we have a quick and easy step by step guide to make your very own customized brand new car floor mats.
Take a time off this weekend and finish a DIY project on custom car mats using superb Goroo car mats. Using the tools and a little bit of hard work you can surely get the end results which will be superb and fancy at the same time. Get professionally designed car mats for your car in any shape or size without having to invest in a lot of money.
So here are simple steps to make your own handmade Goroo car floor mats for your car interiors.
Step 1: Step 1: Do the Measurements
It is a very basic step but often in hurry to start the main process we tend to forget it. To start with you will have to measure precisely where DIY mats are going to fit. You need these measurements for cutting the Goroo DIY mats so do it with utmost precision.
However, if you have old mats that are a perfect fit for your car you can use them to measure the length and breadth of those mats.
Step 2: Step 2: Use the DIY Template
To make it simpler you can use the DIY template to do the measurements of the car mat. This will actually give you the exact measurements.
To do this place the DIY template on a table and then place the front as well as back car floor mats on the template.
Step 3: Step 3: Mark the New Car Floor Mats
Now using a pen or marker draw the layout of the mats on the template. Make sure to not move the mats as it will affect the measurements.
Once you are ready with the layout of all the mats cut each template using scissors. In the end, you will have the cutouts of the new floor mat.
Step 4: Step 4: Time to Use the Goroo DIY Mats
First of all keep the cutouts of the new floor mats aside and clear the table.
Now, using a paper cutter open the carton or box in which the mats are kept and place the Goroo DIY mats upside down on the table.
Step 5: Step 5: Place the Paper Cutouts to Make the Brand New Car Floor Mats
Well, the next step is very important as you do not want the carpet to have the wrong measurements. Take the paper cutouts one by one and place it on the Goroo DIY mat.
Now outline or mark a layout design of the paper cutouts one by one on the car mat. Make sure to do it one at a time for precision. Mark the layout of each cutout carefully.
Step 6: Step: 6 Cut the DIY Goroo Mat As Per the Layout
Now, using scissors cut the layout that you have designed using paper cutouts on the carpet. If the carpet is difficult to cut using scissors you can use a sharp knife too, as want uneven edges on the car mat.
Step 7: Step 7: Clean the Carpet of Your Car
Once you are done with cutting the car mats for your car you must remember to clean the car floor carpet before placing the mats on it. You can use a brush or a vacuum cleaner to clean the floor of the car to keep it dust and dirt free. It is an important step as you do not want to place your brand new custom car mats on the dirty carpet of the car.
Step 8: Step 8: Place the Brand New Car Mats in the Car
At last, once the cutting and cleaning is completed you can place the car mats in the car. Make sure to place the new car mats on the floor first. This will help you in figuring out easily where the mat fits in. Place the car mat carefully. Make sure to see if the accelerator, brake, and clutch are able to function properly on the mat. Similarly, adjust the new mats in the back seat.
Voila! You have your brand new custom made, aesthetic and professional looking ready to use floor mats for your car.
Pro tips – you can also DIY Goroo mats to any other mats you like. For example, door mats, kitchen mats, lounge mats and picnic mats.
2 Comments
5 years ago
Nice tutorial. I wish I had seen this years ago. My last car had a lot of problems with the cheap off the shelf floor mats.
Reply 5 years ago
Hope you like it.
