Introduction: How to Design a Granite Herb Crusher With SelfCAD
Learn how to design a granite herb crusher with SelfCAD
Step 1:
How to Design a Granite Herb Crusher with SelfCAD
In this tutorial, we'll guide you through the step-by-step process of creating a functional and visually appealing granite herb crusher from scratch. This project not only serves as a practical addition to any kitchen but also offers valuable insights into the art of 3D modeling, including shape manipulation, detailing, and precision engineering.
To access the interactive tutorial to this article, check out https://www.selfcad.com/tutorials/4c2jd685b3549442y6k2i1i5g5e3r662t4g4
Once you’ve launched the editor
From the 3D Shapes Category on the Toolbar, choose cylinder. Set Top Radius to 75, Bottom radius to 80, Height to 35, Vertical segments to 64
Click to finalize cylinder
From the Generator’s Category on the toolbar choose Shape Generator. Set Fill top to false, Top radius to 90, Bottom radius to 70, Number of edges to 64, Height to 100, Bevel offset to 1.5, Bevel level to 20, Bevel weight to -2
Set position y to 35
Tick the check mark to finalize shape generator
From the Modify category on the Toolbar choose Add Thickness. Set thickness to 6, Use Mirrored thickness to true
Tick the checkmark to finalize add thickness
Click Move on the Toolbar. Set y to 31
Click to activate Edge Selection
Click on the gear icon to open the Advanced selection tools
Set Loop selection to true
Click on highlighted edge to to select loop from the object
Click ‘x’ to close Transformation panel
From the Modify category on the Toolbar choose Filet. Set Intensity to 3, level to 5
Tick the checkmark to finalize fillet
Click highlighted part on selection cube to turn off region selection. Click on mesh 4 to select it. Click on shape 1 to deselect it. Click to Activate Edge selection
Click on the gear icon to open the Advanced Selection tools. Set Loop selection to true
Click on highlighted edge to select loop from the object
Set Top Radius to 20, Bottom radius to 30, Height to 200, Vertical segments to 64, Position x to -40, Position y to 70, Rotation z to 60
From the Modify category on the Toolbar choose Filet. Set level to 10
Click on shape 1, mesh 4 to select it. Click on mesh 8 to deselect it
Click Stitch & Scoop on the Toolbar. From the Tool panel choose Union
Click to finalize Union
As you continue honing your design skills, remember that SelfCAD offers a wealth of resources to support your learning journey. To deepen your understanding and explore more advanced features, consider checking out the interactive tutorials (https://www.selfcad.com/tutorials) available on the SelfCAD website. The tutorials page provides a treasure trove of guides, tips, and tricks that cater to designers of all levels.
More structured learning experience can also be accessed at the SelfCAD Academy (https://www.selfcad.com/academy/curriculum/), https://www.youtube.com/@3dmodeling101, and 3D Modeling 101 series (https://www.youtube.com/playlist?list=PL74nFNT8yS9DcE1UlUUdiR1wFGv9DDfTB). This comprehensive resource offers in-depth courses taught by industry experts, allowing you to master the intricacies of SelfCAD at your own pace.
