How to Dip-Dye Your Hair With Kool-Aid
Intro: How to Dip-Dye Your Hair With Kool-Aid
Hi everyone, This Instructable is on How to Dip-Dye your Hair with Kool-Aid. Yep, Kool-Aid! Odd isn't it? However, using Kool-Aid to dye your hair, as strange as it may sound, is a great, inexpensive way to dip-dye your hair, and it lasts a long time! When I first did it, it lasted a good 4 months without fading much.
So, what are you waiting for? Let's get started!
STEP 1: Gathering the Supplies
You will need:
Kool-Aid (obviously! :D) I used one packet of tropical punch for a bright red/pink color.
A small pot
A mug
A hairbrush
Hair ties
Plastic Spoon (not pictured)
Note: I only used one packet of Kool-Aid because my hair is naturally blonde, if your hair is darker you may need more packets of Kool-Aid. Also, it depends on the color you are using. Also, dying your hair with Kool-Aid will last a long time, at least for me it did!
STEP 2: Choosing the Pieces of Hair
It's time to choose the pieces of hair you are going to dye. You can dip-dye all the ends of your hair, or you can do some of the ends like I chose to do. I tied the pieces I wanted dyed with a hair tie. In the pictures, you can see my hair is already a little red/pink, that is because I've dyed it before with Kool-Aid. It faded a bit so I am dyeing it again to make it brighter. :-)
STEP 3: Boiling the Kool-Aid
Now we're ready to bring the Kool-Aid to a boil! I poured the Kool-Aid into a small pot and added water. I did not do a specific measurement of water. Once the water is added into the pot of Kool-Aid, stir it with a plastic spoon!
Put the pot of Kool-Aid on the stove, set the heat to high. Put the cover on and wait for it to boil.
Be careful using the stove.
STEP 4: Dying Your Hair!
Once the Kool-Aid has boiled, pour it into your mug. Be careful, the Kool-Aid may stain your counter! Leave your hair in the Kool-Aid for about 5-7 minutes. I left my hair in the Kool-Aid for about 2-3 minutes, since it has already been dyed with Kool-Aid. Time may vary depending on your hair color. Pat your hair dry with a paper towel, then brush it out.
After you have dyed your hair, quickly dry it and your good to go!
Note: On the first day, stay away from rain or swimming. The color will bleed until you wash it. I usually wash mine by the end of the day that I dyed it.
STEP 5: The Result! :)
After you've done all those steps, you should have really cool colored hair! Yay!
I added some pictures of what my hair looks like, and also a before and after picture.
Enjoy!!
33 Comments
Fluffy24 4 years ago
Coolloom 8 years ago
PINK_Gutierrez 5 years ago
no it is not permanent,it only lasts for 6-12 months
BriSwims 7 years ago
no this is not permenant it will onl last up to some months not a year or so
creativity123 8 years ago
It is permanent in the sense that shampooing will not remove it. You may be able to research a method of removal with vinegar, I am not sure how that works. Otherwise, just wait for it to grow out. Hope this was helpful.
ACIDxCOBRA 8 years ago
You can also go swimming and chloride should wash it out
Ggggbbhhrxfsdwxs 6 years ago
what do you wash with after you pat it dry?
Thank u for your instructions creativity123 i really need them
BeckyS90 7 years ago
im doing this method right now. im hoping it works. i have dark brown hair. and its thick so im trying to leave it in longer. like 20 minutes. ill post a picture if it works for me
figureskater223 7 years ago
Mysterious_Gal 7 years ago
Chole Marquez 8 years ago
I do it every week❤️?It's cute!
leahblackwolf 7 years ago
wow I don't have the time to do that!
I've looked at many recipes for Kool-aid hair dye but this is the best method so I decided I should use this out of the 10 or so others!!
Carleyy 8 years ago
Who knew you could do this with coolaid! Very cool!
IWISHICOULDBEMARGO 8 years ago
it's koolaid
that looks AWESOME I am definitely going to try it!!!
DiamondG3 8 years ago
hey my hair is red and i tried purple but it didn't work :( so i was wondering what colors would be best ( i think i will try blue )
Hufflerpuffler1233 8 years ago
