How to Dry Brush Furniture
Intro: How to Dry Brush Furniture
Do you want to find out how to add texture and dimension to your piece, or give your furniture a worn, beachy look? Read this tutorial all about the dry brushing technique!
In this tutorial company co-founder, Rosanne will show you her tips on how to get the best results out of the dry brushing technique on a cute little side table. If you'd rather watch a video, we also have a video tutorial available in the last step!
All of the paint products used in this tutorial can be found on our website at www.countrychicpaint.com.
STEP 1: Pre-paint Your Piece
This technique works best with a piece that has already been given a solid coat of paint; in this case, the table was pre-painted in Cobblestone. If you're unsure of how to prepare your surface before painting, click here to see our surface prep tutorial, and if you'd like to see some tips on how to achieve a smooth finish, click here. It's best to wait at least an hour before you move on to the next step. Your piece should be fully dry before dry brushing.
STEP 2: Pour Your Paint and Prep Your Brush
We recommend pouring a small amount of paint out onto a paper plate before beginning. You can choose any color that you think will compliment your base coat; in this case we chose Sunday Tea and Pebble Beach. We also like to use a chip brush to apply the paint as it will help give you more texture with a naturally worn look to it.
Dab your chip brush into the paint so that just the tips are covered. You don't need much paint on your brush at all so use it sparingly! If you find your brush is too wet, you can dab some off onto the plate or some paper towel.
STEP 3: Dry Brush Your Piece
Using light, quick brush strokes, begin dry brushing your piece. You don't want to apply too much paint, so make sure your brush is quite dry, and your brush strokes are gentle. If you find you've applied too much in a certain area, you can use a damp cloth to remove the paint right away.
STEP 4: The Finished Product
Here's how the finished product turned out. Isn't it pretty? The possibilities are endless, so go get creative!
You can seal this look with wax or Tough Coat for added durability.
STEP 5:
Watch this video to see our company co-founder, Rosanne dry brushing a table with Cobblestone, Pebble Beach, and Sunday Tea!
