How to Effectively Clean a Knife
Intro: How to Effectively Clean a Knife
If you're like me,(and live in the south)you always carry a knife around.And when you find a good one,you want to keep it as long as possible!
In this isntructable,I Will demonstrate the correct,non-damaging,and preserving way to clean a knife.
STEP 1: Tools
For this instructable,you will need:
the knife you need clean;
and a car detailing tool(or an old toothbrush)
STEP 2: The Blade
You'll want to start with the actual blade of the knife;
take the brush attachment of the detailing tool or toothbrush and brush away any visible dust or dirt.If you are using a toothbrush,use it very lightly as to not scratch your knife.If there are any stains,use the heavy attachment for the detailer.If the stain is tough to get of,us a very little amount of window and glass cleaner.If using a toothbrush still use the very little amount of cleaner plus scrub a slight bit heavier than usual.
STEP 3: The Body
Now for the more challenging stuff!
To effectively clean the body of the knife,you will need to get into every nook and cranny.Like the blade,remove the visible dust and dirt with the brush attachment and very light strokes with the toothbrush.Same with heavy stuff,use the tougher attachment and a little bit of window cleaner.With a toothbrush,heavier strokes and little cleaner. now possibly the most important thing to remember for a safe knife you will always want to extensively clean the hinge and place where the knife is folded into!!!If you dont it may end up harder to unfold your knife and eventually not unfolding it at all!!!
STEP 4: Last Notes
I recommend cleaning your knife when you notice a buildup of dirt and grime.If done right,your knife should last for years and serve you plenty!
14 Comments
weaponscollector94 14 years ago
Pfarmkid 12 years ago
go homeschooling!!!
abstracted 12 years ago
notyouraveragejoe 14 years ago
qwerty2008 12 years ago
redsoxdrummer 14 years ago
ernestoaug 15 years ago
Camisado 15 years ago
puppetfunk 16 years ago
im_tux 16 years ago
X_D_3_M_1 16 years ago
austin 16 years ago
jimmyw 16 years ago
toogood 16 years ago
