How to Fix Anet A8 Hotbed Burned Connector
Intro: How to Fix Anet A8 Hotbed Burned Connector
The Anet A8 is a cheap 3D printer very commom on the DIY community that when you put some time working and upgrading will put very good quality prints.
The Anet A8 was the reputation of being a fire hazard do to some faulty parts, one of those parts is the connector to the hotbed.
With this fix the 3D print will became more safe to use by reducing the risk of fire and prevent a failed print.
STEP 1: Burned Connector
This connector is a VHR-6N wire to board with four wires , two for the 12v supply and the two other are for the thermistor that read the hotbed temperature.
This connector can draw 10 amps in normal operation.
You can see on the hotbed the layout of the wires in the connector:
+12v
+12v
Thermistor
Thermistor
-12v
-12v
The terminal inside will became loose with time do to the vibration produce by the 3D printer, the terminal will became isolated do to the small spark and the hotbed will stop working do to the lack of 12v power supply.
STEP 2: Wire Directly
The first thing to do will be desoldering the hotbed connector and solder the wires directly to the hotbed like i did.
This will eliminate the use of the VHR-6N connector.
Take your time desoldering, this will be a little bit tricked because the aluminium in the hotbed will draw all the heat of the soldering iron.
STEP 3: Final Step
To ensure that the wires stay in place and isolated from each other you can apply high temperature silicone.
The silicone can withstand high temperature up to 300ÂșC, more than enough for the working temperature of the hotbed.
All done!
Now you can work with your 3D printer again in a more improve and safe way.
You can check out more projects here:
https://www.youtube.com/channel/UCL-jpfIywlIeSoJ-v...
https://www.instructables.com/member/Engineer+of+N...
Thanks!
5 Comments
abdouessam60 3 months ago
Smiley2182 4 years ago
Engineer of None 4 years ago
eliasrm87 6 years ago
I really doubt that silicon will do anything, I'm pretty sure that it will take no very long before the joints breaks and you got a wonderful short circuit, with all the sparks, smoke and possibly fire included.
The first thing that I always recommend, unless you have very good soldering skills, and here is very important to be honest with ourselves, is buying a new female connector with the six cables populated, so the two positive and negative wires are used. This solution is not perfect, but it is much better than making a mess with the soldering iron...
And last but not least, print one of the one million strain relief available at the web, so the contacts don't move anymore and they will not arc or get loose anymore.
That simple, that easy. No need for soldering or meassy silicones.
Engineer of None 5 years ago
The high temperature silicon is providing strain relief and providing electrical insulation in between wires.
Replacing the burn connector for a brand new is possible but you will have the same problem in the future because this type of connectors are not ratted to work with vibrations produce by the 3D printer.
If any the joints break the security of the update firmware will kick in and stop the print.
Since this post my 3D printer is working non stop without any problem, i have 3D printed all the components of the proton pack of the Ghostbusters, so a lot of filament and a lot of hours working.
