Introduction: How to Install 2002-08 Dodge RAM 40W Cubic LED Fog Light Kit
This tutorial will show you how to install the 40W CREE LED Pod Lights for the following Dodge models:
- 2002-2008 Dodge RAM 1500
- 2003-2009 Dodge RAM 2500 3500
- 2004-2006 Dodge Durango (replaces the OEM halogen fog lights)
This guide is also available as a video walkthrough which you can follow here.
Step 1: Preassemble the LED Pod Light.
Bolt the U-bracket to the LED pod light unit.
Follow the link to learn how to install the U-shaped bracket to the LED pod lights.
Step 2: Route the Bolt Upwards From Under the Bracket.
Step 3: Bolt the LED Pod Light Onto the Mounting Bracket.
Secure the connection with a nut.
Step 4: Directly Replace Your OEM Fog Lights With the LED Pod Light Assembly.
The bolting locations of the mounting bracket matches that of that OEM fog light, allowing you to directly mount your LED pod light the same way the stock fog light is installed.
Step 5: Finishing Steps
Wire your LED pod lights to your existing fog light harness. Test them to make sure they light up.
Once you confirm that they work, close up anything that you opened to perform this installation and enjoy your Dodge RAM/Durango's new LED pod lights!
You can shop for this and more offroad truck LED lighting today!
