How to Install and Boot Damn Small Linux on a USB Flash Drive
94,772
47
132
Introduction: How to Install and Boot Damn Small Linux on a USB Flash Drive
Want to know how to install and boot Damn Small Linux on your usb flash drive then keep reading. you will need to turn your speakers up like the whole way for the video i had some problems with the mic volume
Step 1: Download the Required Files
ok do this you will need a few files
1. Damn Small Linux Embedded click the link and download the zip file ex. dsl-x.x.x-embedded.zip(where the x.x.x is will be the version) http://distro.ibiblio.org/pub/linux/distributions/damnsmall/current/
2. Syslinux once again click the link and download the zip file syslinux-x.xx.zip(once again where the x.xx is will be the version) the link is http://www.kernel.org/pub/linux/utils/boot/syslinux/
(optional but recommended )
1. HP USB Format Tool can be found here http://files.extremeoverclocking.com/file.php?f=197
Step 2: Format Your Flash Drive
I recommend not using the windows formatting tool for the flash drive i heard somewhere it can corrupt the drive and you won't be able to use it any more. open the formatting tool and format your flash drive as FAT
Step 3: Extract the Files You Just Downloaded
Extract Damn Small Linux to your usb flash drive and syslinux to you HDD
Step 4: Make Your Flash Drive Bootable
make your flash drive bootable
1. open a command prompt and got to your syslinux directory mine is C:\syslinux
2. once in the syslinux directory got to the win32 directory mine is C:\syslinux\win32
3. type the command syslinux.exe -ma f: (where f is put your flash drive letter)
Step 5: Change Your Bios Settings to Boot From a Flash Drive
there isn't really any way for me to explain this because everybody's bios is different but ill try
1. restart your computer and press del or whatever you press to enter your bios settings
2. once in your bios you'll want to look for a setting called boot priority or something like that
3. change that so your flash drive is first the bios calls the flash drive a couple different things but it may be usb-hdd or usb-zip or something similar
4. once your setting's are changed save and exit
5. restart your computer with your flash drive plugged in and you should see the Damn Small Linux boot screen
6. if you have any questions or anything please leave a comment or message me
i'll try to get pictures of my bios settings that may help
Step 6: Conclusion
hope this worked for you please commend and let me know how i did i have some pictures of the Damn Small Linux desktop and booting
If you liked this then +1
Be the First to Share
    • Fix It Speed Challenge
    • One Board Contest
      One Board Contest
    • New Year, New Skill Student Design Challenge
    132 Comments
    randofo
    randofo
    13 years ago
    This video looks awesome but you don't have enough instruction besides your video in order for it to be a full Instructable. There are two things which you could do. 1) If you can get some screen captures from your video then you can actually create a full Instructable right from the footage that you already have. First you can create some more steps in your Instructable to explain your project. Then, you can add those step by step screen captures into your Instructable to explain the additional instructions. Once you've done that, you should be good to go, so at that point simply republish your project. 2) If you don't want to turn your video into a full Instructable, that's ok too. That just means that your project should be submitted as a video and kept in our videos section. You can use the same text and embed code that you already have in this Instructable to create a new video in our video section, so it should only take you a few minutes to republish your project. Thanks for your submission and let me know if you have any questions along the way.
    twenglish1
    twenglish1
    Reply 13 years ago on Introduction
    hey thanks for the tips i wrote a full instuctable check it out let me know how i did
    randofo
    randofo
    This looks great! However, there is one more small thing. I know you have a video in the intro step, but before this can be published you need to add a main image to the intro step also. Thanks.
    rmalik3
    rmalik3
    9 years ago on Step 5
    i have a dell inspiron n4050. when i plug in my bootable usb and start my laptop it says
    "remove any media" "press any key to restart"
    my boot sequence is perfect. usb at first position. Please reply.
    sushantnadkar
    sushantnadkar
    10 years ago on Introduction
    i folled your instructions, but after i give the command (syslinux.exe -ma g:), it says
    (Acess Denied
    Did not sucessfully update the MBR.)
    what went wrong please guide....
    captaincoffee
    captaincoffee
    10 years ago on Step 6
    Anyone know how to boot this from grub2. I already have several other distributions, and don't want to wipe my master boot record.
    absolute zero
    absolute zero
    Hey, when you went in the command prompt you lost me. can anyone explain what to do?? i don't really know what he means by changing directory's or any of that stuff as i am not really tech savvy.
    twenglish1
    twenglish1
    ok i can help, where did you extract syslinux?
    twenglish1
    twenglish1
    move the folder to your hard drive its easier to access in a command prompt then open a command prompt and type cd c:\syslinux then type cd win32 then type syslinux -ma (flash drive letter) if you have any other questions just ask
    llingbeck
    llingbeck
    okay so im new to this. i did exactly as you said and at the end this is what it reads Reading boot sector: The parameter is incorrect. what does that mean and what do i have to do?
    twenglish1
    twenglish1
    Check that you extracted the files to the correct place on the flash drive
    absolute zero
    absolute zero
    hmmm...ive pretty much given up on it, my computer support usb booting but it doesnt boot. i dont realy care about it anymore either. its to much of a hassle
    twenglish1
    twenglish1
    yah i don't use it either but i knew how so i made an instructible
    absolute zero
    absolute zero
    Reply 12 years ago on Introduction
    w00tn3ss, i cant believe my patheticness a year ago..........im like supernerdy, coder, hacker geek now................wwwoooooowwwww...................
    hellstudios
    hellstudios
    1 year ago I never even heard of Linux. Now i'm running it on all my computers. :P 1 year ago I didn't know how to build a computer. 1 year ago I thought 1 GB RAM was alot. 2 years ago I thought celeron was a good processor. but yeah this seams like to much of a hassle. I'm running LINUX so those programs that you need to run LINUX won't work on LINUX. D:<
    absolute zero
    absolute zero
    THIS is not a hassle, i have installed somehwere around 15 distro's of linux on flash drives..it just takes a while to get the hang of it
    twenglish1
    twenglish1
    yah i know i got it to work on my first attempt
