How to Keep Your Refrigerator Door Shut
Intro: How to Keep Your Refrigerator Door Shut
My fridge is old and busted. Thanks to a few magnets I was able to save my food from rotting and spreading sickness through the household.
The fridge isn't mine. It came with the house that my wife and I are renting and even though it's not really that old it has a problem with the door after someone banged up the bottom of it by moving it around. You can close the door, but it would open if even slightly jostled.
Closing the freezer door would pop the main door open. There were also times that the door would open on its own. We took to putting a chair up against it, but one day I forgot to do that and it opened up during the day, ruining all the food inside.
I was going to install a new latch or fix the hinge, but I found an even better way: neodymium magnets.
STEP 1: Get Some Magnets
I had a few hundred 1/16" neodymium magnets stuck to my fridge, but you can get some easily enough through several different sources. eBay is a good place to look. I got mine from K&J Magnetics (the D401), but I haven't seen any reason to favor them over any other retailer.
If you're ordering for this purpose, I'd recommend that you try and get a variety pack. I was using 1/16" magnets, but a few 1/32" ones would've helped.
STEP 2: Stack the Magnets in the Gap
On my fridge there is a bit of metal between the magnetic strips and the outside of the fridge. It's not very wide, but neither are these magnets.
I simply kept stacking the magnets and tested the fridge door to see what was a good fit. This takes, oh, about a minute.
STEP 3: Make More Stacks
Now make more stacks so that you have a more secure connection and you're done!
This solution has been working for me for the past month. You can see the proof in this short video that shows how the problem of the freezer door opening the main door was solved.
17 Comments
milindagarwal.agarwal 3 years ago
Milind Agarwal
Michael Blyth 11 years ago
ksafford 13 years ago
nagutron 15 years ago
http://flickr.com/photos/nargopolis/3113672559/
baudeagle 16 years ago
VIPER2475 16 years ago
error404 16 years ago
brad 16 years ago
xorshift 16 years ago
fungus amungus 16 years ago
Kiteman 16 years ago
Hoopajoo 16 years ago
turbonegro 16 years ago
my freezer has an alarm that goes of when the door is open for like 5 (= lights on)minutes but it has a little bit of slack 2-4 mm i have tried to adjust and trim it but there is still a possibility to fuck up thanx for this instructable it cleared my mind about the magnets after all i am a big fan of magnets but i so far i did not think of it as a solution to my own freezer problems thanx again for the eyeopener
