How to Make 1.5V DC to 220V AC Inverter
Intro: How to Make 1.5V DC to 220V AC Inverter
Hello guys, In this Instructable I will instruct you to make your own 1.5v DC to 220v AC inverter with less number of components.
Before going to start don't forget to vote this Instructable .
Subscribe my youtube channel Subscribe
Inverters are often needed at places where it is not possible to get AC supply from the Mains. An inverter circuit is used to convert the DC power to AC power. Inverters can be of two types True/pure sine wave inverters and quasi or modified inverters. These true /pure sine wave inverters are costly ,while modified or quasi inverters are inexpensive.
These modified inverters produce a square wave and these are not used to power delicate electronic equipments . Here, a simple voltage driven inverter circuit using transistors as switching devices.
STEP 1: Components Required
Transformer (6v:220v) - 1 [ Banggood ]
AA Battery Case - 1 [ Banggood ]
Switch - 1 [ Banggood ]
Perforated PCB - 1 [ Banggood ]
BC 547 transistor - 1 [ Banggood ]
BD140 Transistor with heat sink - 1 [ Banggood ]
0.1uF capacitor - 1 [ Banggood ]
30K Ohm resistor - 1 [ Banggood ]
Tools
Soldering Iron [ Banggood]
STEP 2: Watch Video First !
This video gives you all the information you need to build your own 1.5v DC to 220v AC inverter. During the next steps however I will present you some additional information to make the project even simpler.
STEP 3: Circuiting
Here you can find the circuit.
You can see my PCB traces and it is easy to understand while making.
Place all the components on the PCB according to schematic.
Solder all the components carefully.
After circuiting now the time to test with a 220v bulb.
STEP 4: You Made It!
That's all guys you made it.
Feel free to comment.
For more projects and tutorials subscribe my youtube channel [Click Here]
33 Comments
mach1950 6 years ago
hello. What is the frequency of the output please?
YaqoobG 5 years ago
Xavier Frank 3 years ago
JunezRiyaz 6 years ago
50-60hz
ErangaM 4 years ago
HermenioA 4 years ago
Can you help me ? Please
electric_shock 4 years ago
baruahbanani 4 years ago
Post comment...I made this but through 1.5v it gives only 30v...why not 220..through 3.6v it gives 50v..
SumanasiriU 4 years ago
Makoy23 5 years ago
YaqoobG 5 years ago
MichaelW703 6 years ago
How long does it take till the battery is empty?
YaqoobG 5 years ago
DanielC225 5 years ago
GORDONR27 5 years ago
chopsticks-N 5 years ago
how could I generate higher frequencies? specifically, I want the high voltage, but I want to use something to automatically sweep between 300hz - 800hz (I would Likely use a micro-controller if possible), with a goal of reaching 250volts. Would you know if this is possible?
or better question, what is causing the 50hz - 60hz frequency of the stepped up 220 volts?
vijayflyinghumans 5 years ago
kimathijoshua2020 6 years ago
akarshman06 6 years ago
