Introduction: How to Make Arduboy
In this article you will see, how to make mini Gameboy using Arduino Nano. It is also called as Arduboy.
The Arduboy is a handheld game console with open source software, based on the Arduino hardware platform.
Lets make it ...!
Step 1: Components Required
Arduino Nano
I2C OLED display
LEDs( Red – 1, Green -1, Yellow -1 )
Piezo Buzzer
330 Ohm resistors – 3
10K Ohm resistors – 1
Tactile switches – 6
PCB or Breadboard
Step 2: Arduboy Circuit
This Arduboy supports audio effects and lighting effects.
Step 3: PCB Design & Gerber File
I have also made a PCB for this circuit, you can download the gerber file here.
Step 4: Code
First install the above arduboy library.
For installing go to Sketch > Include Library > Add .zip Library > Upload the downloaded library
Now Upload the code. I uploaded breakout game code. You will find it in library examples.
Step 5: PCB Assembly
It will be easy if you watch once and start making.
Step 6: That's All
That's all guys, you have made it!
If you have any query at any step, just comment below. I will respond as soon as possible.
If you want to learn C Programming you can easily learn at codingtute. It will enhance your arduino programming skills.
Thank You.
