How to Make Automatic 12V Battery Charger Simple at Home
Intro: How to Make Automatic 12V Battery Charger Simple at Home
this i my video test. i'm from Vietnam
and this my video test circuit ( this working)
STEP 1: Circuit and
what you need.
1 - diode zener 15v
1 - diode
1 - relay 5v
1 - tip41 transittor
2 - ressitor 220 ohm
1 - ressitor 1k
STEP 2: Make a PCB
here is PCB i make by PROTEUS 8.4
you can download file .PDF and file Projest
Danh sách linh kiện:
" D1 " mk dùng diode thường.
" D2 " mk dùng diode zener 15v.
" R1." mk dùng điện trở 1K ohm.
" R2 " mk dùng điện trở 270 ohm.
" C1" mk dùng tụ hóa 100uf 50v.
" J3 + J2 " nó nằm gần nhau, đây là chỗ mk nối ra led chỉ thị. ( connector to led )
" J4 " là đầu ra acquy (OUT).
" J1 " là đầu vào (12V in)
tytower 7 years ago
Don't like it . You are charging at too high a rate and will destroy the battery . A 12 Volt battery is full at 12.5 Volts . To push current in at 15 Volts is battery murder.
